Transmission Issues Won't Go Into to Gear
- jwm1120
10 Sep 2008 06:24 #236498
by jwm1120
Transmission Issues Won't Go Into to Gear was created by jwm1120
Hello I was wondering if I could get some advice on my 77 KZ 650. My bike hade been sitting for some time with out running. Part of my issue was I needed a new clutch cable. I finally decided it was time to take care of it and start my bike up. I replaced the cable ok and finally got it started. However when I go to kick it into first gear, it acts like it goes, the neutral light is switch off, but I don’t actually go into gear. The bike even jumps a little bit, like the gear was engaged. The bike will go no where. I tried to put it into other higher gears and still nothing. I have even tried with the engine off to put it into gear, then push it to see if I get some sort of resistance, still nothing, it’s like it is still in neutral. So my question is, did I screw something up when replace the clutch cable, forget to put something back, or do I have a bigger problem? Did something maybe break from it sitting to long? Any help or ideas are greatly appreciated.
- Sandy
- Fly High,Tony
- Thank you received: 13
10 Sep 2008 07:29 - 10 Sep 2008 07:31 #236512
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic Transmission Issues Won't Go Into to Gear
1977 KZ1000 A-1
Last edit: 10 Sep 2008 07:31 by Sandy.
- jwm1120
10 Sep 2008 08:25 #236519
by jwm1120
Replied by jwm1120 on topic Transmission Issues Won't Go Into to Gear
Thanks, sorry to post the same thing twice.
- Sandy
- Fly High,Tony
10 Sep 2008 20:29 #236639
by Sandy
1977 KZ1000 A-1
jwm1120 wrote:
No,don't apologize,bud...just wanted you to take a look there,before we got onto YOUR clutch issues,because they sound like they COULD be similar.
1977 KZ1000 A-1
- jwm1120
11 Sep 2008 09:55 #236694
by jwm1120
It did in fact. All I need to do was a little adjusting and wham-o, back up and running. Thanks again for the help.
