oil leak
- tanner
09 Sep 2008 16:15 #236378
by tanner
oil leak was created by tanner
hello i have a 1975 z1900 really love this bike but im getting a oil leak down by my shifter foot that gets oil all over my shoes im going to finish riding this fall i was wandering if anyone had a good place to start this winter
- 79MKII
- Love Them Kaws!
- Thank you received: 43
09 Sep 2008 17:35 #236397
by 79MKII
The Kaw List:
Replied by 79MKII on topic oil leak
I've seen base gasket leaks that run over that far and drip onto the rider's foot. Could be stator cover maybe. There is also a seal behind the front sprocket (very near shifter) but I don't think it would get on your foot from there. Just see if you can determine where it's coming from and let us know.
The Kaw List:
- Thank you received: 2098
09 Sep 2008 17:36 #236398
by Patton
Replied by Patton on topic oil leak
If oil is noticed on front of alternator cover, possible source of leak might be: loose exhaust header pipe clamp (check for loose nuts) or faulty exhaust gasket; leaking tach drive seal; leaking valve cover gasket or half-circle plugs.
Other possibilities include leaking shift shaft seal, or over-lubed drive chain, but either of these usually dips out underneath the sprocket cover without getting so much on shoes and left pants leg.
Good Luck!
Good Luck!
09 Sep 2008 17:38 #236399
by Patton
If an oil cooler is fitted, would also check hoses and connections at the cooler.
- MFolks
- Thank you received: 540
09 Sep 2008 18:50 #236424
by MFolks
Replied by MFolks on topic oil leak
The alternator gasket/grommet has been known to harden with heat and age.
www.z1enterprises.com
sells replacement grommets. You have to cut the ends off the wires,insert them through the new grommet and crimp new connectors on the ends.
Z1 enterprises lists the cost as $12.38 and as a RI grommet.
