Pulling the valve cover - need help!!!
- KOOL RYDER
- KZ 650B2 / KZ 1000E
09 Sep 2008 13:15 #236360
by KOOL RYDER
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
Pulling the valve cover - need help!!! was created by KOOL RYDER
So I am going to pull the valve cover to inspect the camchain guide.....
Other than unbolting the valve cover, what else can I expect to have to do when opening up the top of the engine?
I think that I may have messed up the guide.
Are these cheap to buy and replace.
Other than a ratchet, what kind of tools am I going to require?
A flathead screwdriver to pry the cover off?
What sould I look for when I open her up?
KR
KR
1978 KZ650B
1979 KZ1000ST
- BSKZ650
- Thank you received: 14
09 Sep 2008 13:20 #236362
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic Pulling the valve cover - need help!!!
take out the bolts and it is going to take some wiggle work to get it out, ,,,,, hold your left ear with your right hand and stand on one foot, it works every time
- RonKZ650
- Thank you received: 240
09 Sep 2008 14:00 #236363
by RonKZ650
Replied by RonKZ650 on topic Pulling the valve cover - need help!!!
A 10mm socket is all that's needed. Of course first you need to remove the tank and ignition coils. Be careful lifting the cover to keep all the gasket stuck to the engine if hopefully no gasket sealer has been used, then no need to even change the gasket on reassembly. It's a tight fit pulling the cover up over the top idler sprocket, but it does come off.
- MFolks
- Thank you received: 540
09 Sep 2008 14:33 #236367
by MFolks
Replied by MFolks on topic Pulling the valve cover - need help!!!
Mark your wires and hoses as to where they go so re-assembly leaves no mysteries.
- PLUMMEN
- Thank you received: 104
09 Sep 2008 18:04 #236414
by PLUMMEN
Replied by PLUMMEN on topic Pulling the valve cover - need help!!!
depends on which bike youre working on !
