- Thank you received: 2
6 speed swap ?'s Will it hold up to an 810
- SLEEPER650
07 Sep 2008 14:52 #235997
by SLEEPER650
78 650sr my baby
78 650sr waiting for rebuild
82 kz1100
6 speed swap ?'s Will it hold up to an 810 was created by SLEEPER650
ok so i split the case on my spare engine and the 550 trans will drop right in but the sprocket is held on by a snap ring. i disassembled the shafts and they are different diameters so you have to use the 550 shaft. the other problem is the gears are about 25 to 30% narrower. so my questions are
1. will the snap ring be ok if the sprockets are lined up.
2.will the narrower gears hold up. did kawasaki go over kill on the trans
the new engine is an 810 with a ported 750 head and a set of megacycle 428 lift cams pods and a 4to1
78 650sr my baby
82 kz1100
- kzr750r1
- Thank you received: 9
23 Nov 2008 21:46 #249082
by kzr750r1
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
Replied by kzr750r1 on topic 6 speed swap ?'s Will it hold up to an 810
I've only read of one such build using a 83 (810) Gpz motor and Gpz 550 transmission. No idea how long it would last. Never heard of a long term report with this setup.
Let us know who it goes.
