Oil Cooler, Will it Work?
- 80KAW650
05 Sep 2008 07:20 #235620
by 80KAW650
Oil Cooler, Will it Work? was created by 80KAW650
Well I've finally got my bike running half way decent. It still has it's issues but she's scooting me down the road. I have become concerned however on how hot it gets when occasionally stuck in city traffic and or multiple stop lights: oh how I wish we had turn abouts like Europe. So I'd like to add an oil cooler but I don't have $200-$300 to do it with. I have however come across an oil cooler for an 83 kz550 relatively cheap. Will it fit my 80 kz650 or could it be adapted?
- Sandy
- Fly High,Tony
- Thank you received: 13
05 Sep 2008 07:33 #235624
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic Oil Cooler, Will it Work?
Pretty sure you could adapt it.
You'll have to figure out some fittings though,unless your bike has fittings that will be compatible with the oil-cooler lines.
On the liter-bikes,the factory oil pressure switch(1 piece) has to be replaced with 2 fittings,and they're not all that easy to find.
1977 KZ1000 A-1
- letthegoodtimesroll
05 Sep 2008 08:38 #235632
by letthegoodtimesroll
1977 KZ650C1, Kerker Header, Dyna ignition and coils, GPZ 750 oil pan and cooler
Replied by letthegoodtimesroll on topic Oil Cooler, Will it Work?
I have 1 from a GPZ750 and it is a direct bolt on, I don't think it will be the same for the 550.
