Noise On Left Side?
- Silver
- Old Bikes Are Better!
04 Sep 2008 17:32 #235533
by Silver
1983 KZ750F1 LTD
Noise On Left Side? was created by Silver
Hey guys. I have a "Noise" In the left side of my engine. The older techs at my work say its normal? Sounds to me like the primary drive chain inside the engine. And I have been told this is what it was. Wanna see what you guys think.
Is this normal?
BTW...when idle is at 1300 or more it smooths out till high rpm range only under 1300 R's.
Is this normal?
1983 KZ750F1 LTD
- Z1109R Fin
- Thank you received: 1
05 Sep 2008 04:31 #235589
by Z1109R Fin
Z1000R ´83...Slightly modified...
Replied by Z1109R Fin on topic Noise On Left Side?
Well, IMO idle should be around 1300. These are old machines so can´t expåect them to run as smooth as new, modern bikes. Also you could check the cam chain tensioner. It might be stuck thus leaving too much slack.
- coppertales
05 Sep 2008 08:45 #235634
by coppertales
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
Replied by coppertales on topic Noise On Left Side?
Is this a "rattle" that goes away over 1300 rpm? If so, check your starter clutch for loose bolts. Pull the stator cover and reach behind the rotor and see if you can move the starter clutch. If you can move it any at all, pull the rotor and tighten the bolts, or replace them if they show any damage. You will need to loctite them too. I am assuming the 750 4 has the same set up as the 1000 4....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
- Silver
05 Sep 2008 10:13 #235645
by Silver
1983 KZ750F1 LTD
Replied by Silver on topic Noise On Left Side?
ill check that out next chance I get...
1983 KZ750F1 LTD
- OnkelB
- Thank you received: 80
05 Sep 2008 10:47 - 05 Sep 2008 10:48 #235650
by OnkelB
77 KZ 650 B1, 82 GPz 1100 B2.
Replied by OnkelB on topic Noise On Left Side?
From what you describe it does sound like primary chain noise, my 650 does it too - only cure is a new primary chain which will require splitting the cases. The noise is fairly normal for the 650s/750 fours and not really anything to worry about, I have never seen or even heard about a primary chain breaking.
The 650s/750 fours do have a different starter clutch setup than the big bikes, they have the starter clutch sitting on the secondary shaft behind the crank - the primary chain is what ties the the crank and the secondary shaft together through the starter clutch.
The pic below shows the primary chain and starter clutch on a 650 engine with the secondary shaft half removed - as you can see the chain is about an inch wide and not likely to snap.
Last edit: 05 Sep 2008 10:48 by OnkelB.
- Silver
05 Sep 2008 11:00 #235651
by Silver
1983 KZ750F1 LTD
Thats what i figured...run er till she blows...lol
1983 KZ750F1 LTD
