how long before damage occurs?
- School Teacher
04 Sep 2008 13:36 #235497
by School Teacher
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
how long before damage occurs? was created by School Teacher
if you are running lean,( i was running 136 mains-they were running a tad rich- but I thought they said 130, i went down to 125's and they ran lean)
they were on a kz1000- i ran it for around 80 miles this way
also where is damage most likely to occur
1980 kz1000G1
- Thank you received: 2098
04 Sep 2008 13:54 #235499
by Patton
Replied by Patton on topic how long before damage occurs?
School Teacher wrote:
Doubting any damage was done, because main jets don't do much below wide open throttle. And no mention of the bike having been "pinging" or over-heating for the 80 miles.
went down to 125's and they ran lean - was this evidenced by plug reading after high speed throttle chop with simultaneous killed ignition?
Imo, the best evidence of correctly sized main jet is a nice clean tan plug reading after the mentioned high speed throttle chop. As this truly shows what's going on inside the combustion chamber at wot where the main jet size is governing the mixture.
Good Luck!
Good Luck!
- School Teacher
05 Sep 2008 12:05 #235656
by School Teacher
1980 kz1000G1
Replied by School Teacher on topic how long before damage occurs?
ok guys the 80 miles lean did nothing bad to it !!!!! yeah!
but i found out if you drop a bolt down the intake it does not do good things to your valve train or the top of your piston!!!!!!!!!!!!!!
patton thanks for the info though.
1980 kz1000G1
