Valve info
- 77_650B1
Also what sizes are the stock intake and exhaust valves? And how big can the intake go out to?
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- BSKZ650
- Thank you received: 14
There is a lot of special equipment used in doing a valve job, you ask about material for valve seats, there is a specific hardness and press that has to be done just right or things will go way bad in addition the correct placement of the seats along with grinding them correctly to match the valve face.
I know doi it yourself is fun, but the machines and skill to use them goes a long way
77 ltd1000, current rider
76 kz900, just waiting
- 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- BSKZ650
with that being said, you dont turn the valve in a lathe, you grind them on a valve grinding machine, the lathe will cause the valve to flex thus not being true.
I was trying to be nice and help you out and keep you from having a problem, with that being said, your on your own
- 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- steell
Right on. Did I say I was putting valves in lathes?
No, but you could
You could use a collet to hold the valve in the spindle, then use a tool post grinder to grind the valve.
You can also bore a cylinder block on a lathe, make a fixture to mount the block on the cross slide, then run a boring bar between centers.
Unfortunately, none of the above has anything to do with your original question
I think you're asking the wrong people, you probably should ask the people at www.practicalmachinist.com by posting in the General forum there.
I know what CNC is, and basically how it works, but I have no experience with any cnc machine, not even a cnc router
And good for you for wanting to do it yourself!!!
- shighley
You'll probably end up making a sine fixture large enough to position the head for the mill work. My 0.02 cents worth, ride safe, Steve
\'74 Z1-A, Bought new, worn out 3 times, being ridden now
\'83 XVZ12TK, was daily driver until frame broke
\'78 KZ650SR-D1A, Son's bike, I'm the wrench (He's young)!
- bountyhunter
- Thank you received: 337
I appreciate that, but if you dont know the answers to any of my questions dont post please. Why assume I dont have the knowledge
Here is some knowledge you may not have: just making valves bigger does not mean you will get better flow or more HP, in fact, it may screw it up worse than it is now.
As for valve seat angles, my FSM says to use:
75 deg (top chamfer)
45 deg (main face)
30 deg (bot chamfer)
going from the outer surface of the head in.
- 77_650B1
Steell, wouldn't it be easier to make a boring bar of the right diameter for boring the cylinders, and do it on a mill?
I hadn't thought about a taper, thats surely something to think about too. I've got a few engine design books here I have to look at. I'll be crunching the numbers too over the next few months to see what size valves to use with the 810cc.
(PS - I'm a mech engineering student in my 5th year university, this will be a nice project for me.)
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- steell
And I've worked hard to gain those qualifications
If you have a mill with enough vertical travel to bore the cylinder, then that is easier, but if your mill doesn't have the required travel, then the lathe takes over.
I don't care if it costs me $1 and twenty hours labor to make something I can buy for $30, I'll learn something in the doing that will last me the rest of my life, and more than likely be needed again to make something else.
And besides that, it's fun
- 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- shighley
steell and 77_650B1, I sure like your attitude on the learning process. I agree that the little "pearls" of knowledge I have were at the expense of making mistakes! It seems that is the way I learn best. I've been torturing raw material into usable components for my adult life, so I have some answers on some subjects. If I can help, I'll enjoy it. Ride safe, Steve
