Did I break something?
- ghunt81
01 Sep 2008 15:07 #235034
by ghunt81
1978 Kawasaki KZ750 Twin- Coil mod, Dyna coil, 7mm copper core wires
Did I break something? was created by ghunt81
I rebuilt the carbs on my bike last night and today I've been trying to get it started so I've been cranking it a fair bit.
The last few times I've cranked it, it cranks for 2 or 3 seconds and then it sounds like the starter disengages and is just spinning. If you let off and crank it again, it does the same thing. What's going on?
- steell
01 Sep 2008 15:16 #235036
by steell
Replied by steell on topic Did I break something?
If the battery is not fully charged, that will happen, if the battery is fully charged, then you may need a starter clutch rebuild kit.
- ghunt81
01 Sep 2008 15:19 #235037
by ghunt81
Replied by ghunt81 on topic Did I break something?
Ah....no, the battery is on a charger, but it had seemed to be cranking fine earlier....guess I'll leave it alone for awhile.
- ghunt81
02 Sep 2008 18:27 - 02 Sep 2008 18:34 #235195
by ghunt81
Well crap, apparently my starter clutch is dead
Where can I get a rebuild kit for it?? I can't find one anywhere!
edit: Bike Bandit lists a "starter clutch assembly" for $100...ouch I'm guessing that's what I need, isn't it?
Last edit: 02 Sep 2008 18:34 by ghunt81.
- Sandy
- Fly High,Tony
- Thank you received: 13
- ghunt81
02 Sep 2008 20:15 #235213
by ghunt81
"everywhere" includes z1, yes...
