all i got is...
- grinch77
1978 KZ650\'82 KZ750 motor
1991 SE-R
Coweta,OK
- bill_wilcox100
- Thank you received: 5
Typical causes are reversed left and right coil wires. Could also be reversed points/detectors under the ignition cover.
Best of success.
PS
Don't forget to add your year, model and location to your signature for the best responses and it's considered real friendly too.
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
- steell
- grinch77
1991 SE-R
Coweta,OK
- Sandy
- Fly High,Tony
- Thank you received: 13
Did you have that apart?
If you did,you might have put it back together,180 degrees out,like mentioned.
1977 KZ1000 A-1
- grinch77
1991 SE-R
Coweta,OK
- The Milkman
- Thank you received: 194
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- OnkelB
- Thank you received: 80
can some one post a pic of the part that needs to be turned.the one I thought it was is keyed to the crank no turning it.
You're correct that the advancer itself is keyed to the crank and can only go on one way. However the points cam lobe (the center of the advance where the weights fit into) can be turned 180 degrees. Very easily verified on the 650: there's a scribe mark on the outer edge of the points cam lobe - that mark should point towards the hole in the backplate like in the pic below:
77 KZ 650 B1, 82 GPz 1100 B2.
- grinch77
This morning i checked to see if I still have spark at the plugs I'm good there.Checked voltages to everything good there.So I'm down to either I have the carbs hooked up wrong or the points are shot.
Also when I turn the petcock to prime it just pukes gas out of the overflow tubes so I'm not sure what is going on there.
1991 SE-R
Coweta,OK
- grinch77
1991 SE-R
Coweta,OK
