Run like an 1100 GPZ?
- Exitpupil
30 Aug 2008 18:47 #234739
by Exitpupil
79 KZ1000 LTD B3, 1075 kit, BS34 carbs, high velocity ported heads, K410 cams, V&H pipe w/custom baffle
Run like an 1100 GPZ? was created by Exitpupil
I had a beautiful 83 GPZ 1100 that I foolishly sold. I now have a 79 KZ 1000 LTD. What mods would I need to get it to match the power of the GPZ?
- MFolks
- Thank you received: 540
30 Aug 2008 19:22 #234741
by MFolks
Replied by MFolks on topic Run like an 1100 GPZ?
Some places to look:
1. www.kzzone.com
2. www.redlinecycle.com
3. www.partsnmore.com
4. www.sudco.com
5. www.dynoman.net
6. www.z-power-co.uk
7. www.zpower.com.au/catalog
1. www.kzzone.com
4. www.sudco.com
5. www.dynoman.net
- steell
- larrycavan
- Visitor
31 Aug 2008 12:28 - 31 Aug 2008 12:31 #234806
by larrycavan
Replied by larrycavan on topic Run like an 1100 GPZ?
Exitpupil wrote:
Why match it when you can beat it?
88CFM @10" cylinderhead w/stock 36mm valves
1075cc 10.5:1 compression JE pistons
Web #110 Grind cams
31mm Keihin CRS Smoothbore carbs
That combo will give you everything you want & more.
Web #110 Grind cams
Last edit: 31 Aug 2008 12:31 by larrycavan.
- Exitpupil
31 Aug 2008 18:40 - 31 Aug 2008 18:43 #234871
by Exitpupil
Replied by Exitpupil on topic Run like an 1100 GPZ?
I think I'm on the way then! I got the 1075 kit, ported head, K410 cams and 34BS carbs. Now to get it tuned right. Thanks for the encouragement.
Last edit: 31 Aug 2008 18:43 by Exitpupil.
- larrycavan
- Visitor
01 Sep 2008 07:16 #234941
by larrycavan
Exitpupil wrote:
There you go!
Just curious, what's the head flowing @10" ? You did get a flowsheet right?
There you go!
- Exitpupil
01 Sep 2008 08:07 #234958
by Exitpupil
Larry, sorry no flow sheet. This is a head I got your calculations for a year or two ago and ported myself according to your recommendations. I'll post how it runs when I get her dialed in. The carbs were jetted wrong and I had been fighting that because I just found the main jet was not what I was told it was. How much am I loosing from using the stock valve seat angles? I only lapped the valves as they had 4K miles on them.
