My Transmission leaks around the Shifter Arm Shaft
- Stevec6535
27 Aug 2008 06:37 #234214
by Stevec6535
My Transmission leaks around the Shifter Arm Shaft was created by Stevec6535
My Transmission has a small leak coming from the Seal around the Shaft for the Shifter Arm. The Bike is a 1981 Kawasaki KZ750 H2 4 Cylinder. It looks like I need to replace the bushing or seal around the Shaft. Has anybody had to do this? and where did you get the new seal?
Thanks
Thanks
- RonKZ650
- Thank you received: 240
27 Aug 2008 07:08 #234216
by RonKZ650
Replied by RonKZ650 on topic My Transmission leaks around the Shifter Arm Shaft
Part # 92051-005. Should be stock I would think at most servicing dealers.
- Stevec6535
28 Aug 2008 12:04 #234455
by Stevec6535
Replied by Stevec6535 on topic My Transmission leaks around the Shifter Arm Shaft
My local Kawasaki Dealer says that they cannot get. I also looked on Z1enterprises web site and did not find one. Any suggestions?
- RonKZ650
28 Aug 2008 13:43 #234470
by RonKZ650
They have to be mistaken. The seal was used for 20+ years on everything from a KX80 to a Voyager 1200. Bikebandit has them listed for around $3.50. Just listed doesn't mean they are always available, but if they quit making seals that were used in millions of motorcyles we're in trouble.
- SPARKY47
- 1980 KZ500 B2
- Thank you received: 5
28 Aug 2008 13:58 #234473
by SPARKY47
1980 KZ500 B2
Replied by SPARKY47 on topic My Transmission leaks around the Shifter Arm Shaft
1980 KZ500 B2
- SPARKY47
- 1980 KZ500 B2
28 Aug 2008 14:00 #234474
by SPARKY47
1980 KZ500 B2
1980 KZ500 B2
- OKC_Kent
- Thank you received: 20
28 Aug 2008 15:22 #234495
by OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Replied by OKC_Kent on topic My Transmission leaks around the Shifter Arm Shaft
They are very easy to replace. I recall having to remove the outer cover, picking out the old seal, cleaning everything up, and sliding the new seal over the shaft and into place.
Wrap a single layer of masking or electrical tape over the shaft splines to keep the seal from catching on a burr and ruin the seal..
When you remove the old seal a small amount of oil may follow, it did on mine.
Oklahoma City, OK
- gpzrox
28 Aug 2008 23:37 #234549
by gpzrox
84 GPZ750. Modded with stock Kawasaki parts: ZR-7 shock, ZX-6 coils, GPZ1100 throttle, EN454 brake, GPZ900 fuse box, etc. and non stock: Ken Sears mirrors, K&N filter, Pirelli Sport Demons.
Replied by gpzrox on topic My Transmission leaks around the Shifter Arm Shaft
I saw them on RonAyers.com also.
- Stevec6535
29 Aug 2008 06:37 #234579
by Stevec6535
I orderd the seal and the gasket from bikebandit.com today. Thanks to everybody for all of the advice, it makes this project more enjoyable.
- hugo
- '92 Zephyr 750
- Thank you received: 71
29 Aug 2008 07:40 - 29 Aug 2008 07:42 #234596
by hugo
Replied by hugo on topic My Transmission leaks around the Shifter Arm Shaft
I did it on my '91 Zephyr 750, which is basically a generic KZ750 engine, about a year ago. In my case, it was the counter shaft oil seal that was bad, but I ordered it, plus the one on the shifter anyway. Both from Bike Bandit.
Transmission plate has to come out, the neutral indicator wire disconnected. The counter shaft oil seal is a big one and easy to remove and replace with fingers. The one on the shifter shaft is small and tight. I needed a seal driver/extrator to deal with that one. Everything went well.
Last edit: 29 Aug 2008 07:42 by hugo.
- 84GPZrider
29 Aug 2008 13:04 #234638
by 84GPZrider
Replied by 84GPZrider on topic My Transmission leaks around the Shifter Arm Shaft
I just replaced this last nite and more than a little oil comes out when you get old seal out!!!lol
I ordered the new one thru a local repair shop who orders from a Kawasaki distributor.
It came in a genuine Kawasaki package and cost me 6 bux.
The part# on the package is 92051-005 and this was for my GPZ750.
- Stevec6535
29 Aug 2008 13:24 #234641
by Stevec6535
Did you have to remove the Trans Sprocket? If so What did you use to get the Trans Sprocket off. Mine seems to be on there nice and tight. So tight that my Impact Wrench will not budge it.
