Weird misfire of some sort?
- ghunt81
25 Aug 2008 15:45 #233961
by ghunt81
1978 Kawasaki KZ750 Twin- Coil mod, Dyna coil, 7mm copper core wires
Weird misfire of some sort? was created by ghunt81
I rode my bike to work today, ran fine the whole way there.
Today I went to go home, and right after I pulled out onto the road the bike was running rough and couldn't even maintain 40 mph.
It almost sounded like it was only running on one cylinder. I pulled off the side of the road, and it didn't seem to want to idle. I had no idea what it was, tried to run it for a few minutes, and then it was fine, and I rode it all the way home and it was fine. :huh:
What happened?
What happened?
- bountyhunter
- Thank you received: 337
25 Aug 2008 16:02 - 25 Aug 2008 16:04 #233965
by bountyhunter
Replied by bountyhunter on topic Weird misfire of some sort?
My 750 twin used to do that when crud from the fuel line would get into a main jet. Eventually gas would flush it clean and it would suddenly run OK.
Last edit: 25 Aug 2008 16:04 by bountyhunter.
