Discharge out the right exhaust
- dnpurdy
23 Aug 2008 20:25 #233654
by dnpurdy
(1980 KZ440-A1 sold project bike)
(1982 KZ750-N1 still stolen)
1982 KZ750-N1, my only now
Discharge out the right exhaust was created by dnpurdy
Quick question because I don't know where to go with figuring out this problem for my 1982 KZ750N1 Spectre.
I recently took off my head to EDM out a broken exhaust stud on #3. This went great and I was able to put a new stud in just fine. As I remember, the EDM did a perfect job.
I put the head back on with a new head gasket, reshimed all the valves to .12 mm dead on, and used all new exhaust copper gaskets. I removed the smog stuff and put a piece of hose between the two ports on the front of the head where the smog used to connect. I had also dropped the exhaust and mufflers and cleaned them all up.
Before I did this work, I was getting nearly 55 mpg. Now, I get the fuel like after 30 miles. That's ~10 mpg??? Also, I have a blackish oil discharge out the 3/4 muffler that was not there before.
I have checked compression on and all cylinders are spec. I have used new spark plugs and checked the timing. I had cleaned the carbs and checked the fuel level today. A mm or two high, but still below the mating surface by 2 mm on both #3 and #4. Having checked all the usual suspects, I'm looking for what to check next.
I don't know if the discharge and the terrible mileage are related, but I going to assume there are since they appeared at the same time.
I didn't seem to be burning or spewing any oil, it was still full. I drained the oil today for a change and will fill it to the full mark tomorrow and watch it closely. The drained oil had no discernible smell of gasoline, so I don't think it when to the crankcase.
Ideas?
Ideas?
- Dragone
23 Aug 2008 20:59 #233661
by Dragone
Replied by Dragone on topic Discharge out the right exhaust
Good question. How do the plugs read?
- Royal1MC
- Is it just me, or is it just great to be on a KZ
23 Aug 2008 22:17 #233680
by Royal1MC
*1980 Z1-R (current))
*1978 KZ1000 LTD w/ Z1-R frnt end (sold)
*1977 KZ650 B1 (sold)
Los Angeles, CA
Replied by Royal1MC on topic Discharge out the right exhaust
Possibly valve seals for the discharge. You removed the smog pump, could be the reason for the change in milage.
Los Angeles, CA
- steell
23 Aug 2008 22:32 - 23 Aug 2008 22:33 #233683
by steell
Replied by steell on topic Discharge out the right exhaust
Here we go again with the invisible smog pump :whistle:
The smog removal had exactly zero to do with any drop in mileage, same effect it has on performance.
It's pretty obvious you are pumping fuel out number 3 or 4 (if not both) cylinder. 10 mpg means you are pumping an awful lot of fuel through one or two cylinders, and I'm going to guess that it's just one. I'm going to go out on a limb here and suggest that you left a part out of one of your carbs. Either #3 or #4 spark plug ought to be wet with fuel, so pull them out and see which plug it is, then pull the corresponding carb apart and see what part is missing.
If WG was here he could probably tell you exactly what part you left out, but I'm going to guess that it was the main jet.
Last edit: 23 Aug 2008 22:33 by steell.
- Thank you received: 2098
24 Aug 2008 05:29 #233715
by Patton
Replied by Patton on topic Discharge out the right exhaust
Any fuel coming from the floatbowl overflows?
- dnpurdy
24 Aug 2008 08:58 #233735
by dnpurdy
Replied by dnpurdy on topic Discharge out the right exhaust
prize goes to steeel
dropped the #4 bowl and the secondary main jet had unscrewed itself and was sitting at the bottom, leaving a gaping huge unmetered fuel passageway to #4.
- Locozuna
24 Aug 2008 10:22 #233741
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Replied by Locozuna on topic Discharge out the right exhaust
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- Sandy
- Fly High,Tony
- Thank you received: 13
24 Aug 2008 11:00 - 24 Aug 2008 11:01 #233743
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic Discharge out the right exhaust
I'm totally impressed!
Wholly crappers,Steell...how the??...??:ohmy:
Can you come up,and run our country...please?:woohoo:
1977 KZ1000 A-1
Last edit: 24 Aug 2008 11:01 by Sandy.
- steell
24 Aug 2008 11:14 #233744
by steell
Logical thinking, it's a character flaw I'm well known for
Ever notice that I don't post much in the body work and paint forum? That's because I don't have an artistic side, without logic I'm lost
- Sandy
- Fly High,Tony
24 Aug 2008 13:15 #233760
by Sandy
1977 KZ1000 A-1
Artistic-schmistic...leave that for the "Wing-Man":laugh:
(absolutely no offense,Mark)
You NAILED it,Steve!
Keep up the with the logical thinking...you could learn something from yer bad self.
You rock,you Hooligan.:laugh:
1977 KZ1000 A-1
- Locozuna
24 Aug 2008 16:56 #233797
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
