kz1000 head question
- pinhead
22 Aug 2008 13:30 #233495
by pinhead
kz1000 head question was created by pinhead
Will a head from a 1976 kz1000 fit a 1980 kz1000?
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
22 Aug 2008 14:19 #233500
by Skyman
West Linn, OR
Replied by Skyman on topic kz1000 head question
Is this a trick question? :laugh:
I assume you either mean a '76 KZ900 or a '77 KZ1000--Kawisaki did not make a '76 KZ1000, I believe.
If it is a '77 KZ1000, then the answer is yes--assuming that the bike you want to put it on is really a 1980 model. :blink:
I'm pretty sure a '76 KZ900 head can also be bolted onto a 1980 engine, but I'm not absolutely positive.
West Linn, OR
- donthekawguy
- Thank you received: 8
22 Aug 2008 14:36 #233503
by donthekawguy
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
Replied by donthekawguy on topic kz1000 head question
It will only fit a LTD model. The 79-80 a2a, mkII and shaft have the smog heads on them.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- pinhead
22 Aug 2008 16:18 #233518
by pinhead
Replied by pinhead on topic kz1000 head question
sorry, you're right it is a 76 kz900 head. and it is going on a 1980 kz1000.
- pinhead
22 Aug 2008 16:29 #233519
by pinhead
OK this is a question that i have been meaning to get to. How do I teel if it is a limited. It came with no markings on the side covers due to it being custom painted. The vin is kzt00b535398.
- mtkawboy
- Thank you received: 16
22 Aug 2008 16:40 #233520
by mtkawboy
Replied by mtkawboy on topic kz1000 head question
Sorry to barge in but whats a smog head vs the LTD head ? I thought they were both MK2 heads
- Royal1MC
- Is it just me, or is it just great to be on a KZ
22 Aug 2008 17:07 #233523
by Royal1MC
*1980 Z1-R (current))
*1978 KZ1000 LTD w/ Z1-R frnt end (sold)
*1977 KZ650 B1 (sold)
Los Angeles, CA
Replied by Royal1MC on topic kz1000 head question
Any KZ after 1978 came with a smog pump which attach to the valve covers. The cylinder head has a extra port, right behind the exhaust side of the head. If you go to Kawasaki site (parts diagram) you'll see the difference. Type in both 1978 and 1980 KZ000.
Los Angeles, CA
- steell
22 Aug 2008 17:42 #233524
by steell
Replied by steell on topic kz1000 head question
Royal1MC wrote:
(1) Not every KZ sold in the US after 1978 had the smog ports, the 750 twins didn't get the smog ports till the 82 model.
(2) No pump on the valve covers or anywhere else, on any KZ, it's a simple vacuum controlled system that allows fresh air to be pulled into the ports.
(3) Bolt the 900 head on the 80 KZ1000 if you wish, just use the 900 cam/valve cover. You can also bolt the 1000 head on a 900, just plug the holes that lead into the ports and use the 900 cam/valve cover, it's done all the time.
I used epoxy to plug those holes, others tap them and screw in plugs.
