Troubleshooting - firing issues
- BeeSting
- Drive it like your tax dollars already paid for it
21 Aug 2008 19:48
Alright, here's whats going on.
I still have alot of fuel ending up in the airbox. The bike is bogging alot, and at all speeds now.
All the pipes get hot enough to immediately vaporize water, but the #3 pipe doesn't vaporize it (immediately) right at the first bend (coming from the cylinder). lower down the pipe is does. This boggles me...
I'm probably going to get a cylinder pressure checker again. What should my procedure be and what should I look for?
I'd like to get some more road time before the season is over. Thus far I've been proud to ride my old Kaw and proud to put down a couple new Harleys in the process.
BeeSting
Flint, Michigan - Chicagoland, IL
If I wasnt such a badass American, I would have to drive a Harley to make up for it
1980 Kawasaki KZ750 H1 LTD (4)
Kurayami (Girl of Darkness)æš—é—‡ã®å¥³
1980 Honda CX500C - GONE
Christine
Christine
- KZQ
- Administrator
Re: Troubleshooting - firing issues
21 Aug 2008 21:09 - 21 Aug 2008 21:12
What do the plugs look like?
Sorry can you link me to the thread in which you discussed your previous history?
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
Last edit: 21 Aug 2008 21:12 by KZQ.
- BeeSting
24 Aug 2008 20:15
I'll need to look at them again. I know that #3 looks lean/overheated.
BeeSting
Christine
Christine
- BeeSting
25 Aug 2008 07:12
Checked the plugs again. #1 is fouled (sooty), #2,#3, and #4 are dry-lean.
BeeSting
Christine
Christine
- steell
25 Aug 2008 08:16
More than likely there are at least a couple of separate problems.
#1 probably has a leaking float needle valve, and the other three probably have vacuum leaks.
#1 could have a vacuum leak also, with the leaking float valve covering up the symptoms.
- BeeSting
27 Aug 2008 14:43
There is dark colored dirt on the engine side of the rubber flanges that mount the carbs to the engine/head. Is this normal or a sign of some sort of leak?
BeeSting
Christine
Christine
