Help! Starter Clutch???
- BLR_STS
Another newbie with another question. haha First off my bike is a 1981 KZ750 I have just replaced my starter clutch because when I went to start it, it cranked, and caught a little bit and then spun. It did this multiple times so, I replaced the starter clutch. I went to start it and it cranked and caught great and started right up. After a couple more starts it started doing the same thing again. Cranking, catching then spinning. Could this be the starter clutch again??? Any help or advice is appreciated greatly!
-Josh
1981 KZ 750
- ThatGPzGuy
- Thank you received: 385
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- ronjones
- Thank you received: 4
- Sandy
- Fly High,Tony
- Thank you received: 13
If that's possible,maybe the rotor came loose,or it sheared off the woodruff key?
1977 KZ1000 A-1
- steell
Not too sure on the 750,but maybe the rotor is spinning on the crank??
Assuming it's a KZ750 four, the starter clutch is on a secondary shaft inside the motor. It's not near as easy to repair/replace as it is on the twins and the 900/1000/1100 motors.
- Sandy
- Fly High,Tony
That would suck.
(note to self...keep my bike)
1977 KZ1000 A-1
- ThatGPzGuy
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- BLR_STS
1981 KZ 750
- ghunt81
Gonna pull it off tonight and see how it looks.
1978 Kawasaki KZ750 Twin- Coil mod, Dyna coil, 7mm copper core wires
- Grantl
- KZRider is Da Bomb!!!
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
- ThatGPzGuy
GrantL is right. The springs on mine were wasted. It only took about 20 minutes to rebuild the whole thing and get it back into the cases. Make sure you use Loctite to keep those fasteners in place. It took much longer to put the engine back in what will the cleaning/re-painting and gasket scraping. It now starts up like a champ.
Good luck.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- ghunt81
