Muffler Tip
- Colos
20 Aug 2008 19:24 #233194
by Colos
Muffler Tip was created by Colos
Hi, all. This is my first post and I have a 1979 KZ650 C3 that I only got about two months ago. The other day I was on the highway when the end blew off my muffler. I was only a couple of minutes from home. I still have the baffle, but there is no longer any packing or "tip" on the end. I drove back to the spot where it happened, but I couldn't find it anywhere.
I believe that the bike has the original exhaust (4 into 1 Kerker). My question is this: The rest of the exhaust system is fine. Is there anywhere that I can get a new tip for the muffler to avoid buying a whole new exhaust (it's not really a tip, as it was inset to begin with)? I've done a lot of searching and all I've been able to find for this particular exhaust is to purchase a whole new system for around $500.
Any help is greatly appreciated. Thanks!
- MFolks
- Thank you received: 540
20 Aug 2008 19:54 #233203
by MFolks
Replied by MFolks on topic Muffler Tip
sounds like the screws backed off and out came the baffle!
www.supertrapp.com
(they make Kerker parts too)
- Bluemeanie
- Thank you received: 14
21 Aug 2008 05:49 #233243
by Bluemeanie
Replied by Bluemeanie on topic Muffler Tip
Dennis Kirk
has them too. I ordered one about a year ago.
- rstnick
- Thank you received: 377
21 Aug 2008 06:24 #233249
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic Muffler Tip
Welcome.
I'd like to see that C3 of yours, one of the best kzs in my opinion. Do post up a picture or two.
They came with a 4 into 2 system originally.
The Kerker is an aftermarket exhaust system.
I tried removing the end cap on mine, and couldn't get the screw out, and here yours goes and falls out on it's own. :blink:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- OKC_Kent
- Thank you received: 20
21 Aug 2008 07:36 #233260
by OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Replied by OKC_Kent on topic Muffler Tip
This was just posted recently, maybe it'll work for your system.
kzrider.com/index.php?option=com_kunena&...ew&id=232774&catid=2
Oklahoma City, OK
- Colos
21 Aug 2008 10:59 #233287
by Colos
Replied by Colos on topic Muffler Tip
Thanks for all the advice! I actually ended up finding a replacement Kerker end cap at denniskirk.com. It will be here on Tuesday. In the meantime, I'm going to pick up some fiberglass filler to repack the muffler. I'll let you know how it goes.
As soon as I get a chance, I'll post some pics. She needs some cosmetic work, but runs like brand new (or will again, once I have the muffler back together)!
I actually got it, not running, for $250! It only needed new tires, carbs cleaned, and a new coil - although the right front fork has started to leak very slightly now...
