1st - Neutral - Nothing
- redline
20 Aug 2008 13:10 #233133
by redline
1st - Neutral - Nothing was created by redline
Wondering if some one can help me out on this new problem i seem to be having. I recently got the clutch cable installed on my bike by a local shop. Because the bike is not running at the moment, i never checked to see if the bike went through all the gears. It engages first, and neutral, but it wont shift up any higher.
I went back to the shop where this was done and he told me it has nothing to do with the clutch but more likely the gear box. this bike has not been running for 3 years now and it was fine before it went into storage. Is this a clutch problem, or is he right and it has nothing to do with the clutch cable he installed. Gear box seazed from sitting for 3 years ??
thanks all
78kz 400
thanks all
78kz 400
- KruZer
20 Aug 2008 13:28 #233137
by KruZer
*1977 1000, 1975 KZ998 LSR bike.
Replied by KruZer on topic 1st - Neutral - Nothing
Probably nothing wrong with the tranny.
The bike has to be rolling before you can engage second gear and higher.
It a positive stop device for finding neutral.
Either put the bike up on the center and spend the rear wheel as you shift the bike up through the gears or set on the bike (bike running or not) and coast down a small grade and shift up through the gears.
Hope this helps.
Buzz
Hope this helps.
Buzz
- RonKZ650
- Thank you received: 240
20 Aug 2008 13:31 #233138
by RonKZ650
Replied by RonKZ650 on topic 1st - Neutral - Nothing
Sitting for 20 yrs won't bother the transmission, unless water is in there. It looks like KZ400 used the positive neutral finder that keeps second gear from being engaged unless the motorcycle is rolling, so I'd bet this is all it is and you don't have a problem.
- littlemanonbigbike
20 Aug 2008 15:27 #233153
by littlemanonbigbike
1982 1100 Spectre
Various other toys
Replied by littlemanonbigbike on topic 1st - Neutral - Nothing
My 1100 Spectre has to be moving to get 2nd and higher too.
1982 1100 Spectre
Various other toys
- redline
21 Aug 2008 07:34 #233259
by redline
Replied by redline on topic 1st - Neutral - Nothing
thanks guys, i'll give that a shot
