Camchain adjuster modification
- DesertWizardB1
12 Feb 2006 06:31
Hi guys, Here is a little mod I did to my camchain adjuster that a friend that races told me about. It makes it less likely to loosen up and fail. The mod is not to hard to do. You just remove the adjuster and drill and tap the end of the adjuster for a 6/32 screw. You can use it as an extra lock or to put a little more pressure on the chain if you think your spring tension is weak. To use it as an extra lock just adjust your camchain as usual and tighten the bolt then turn in the 6/32 screw in to it hits the plunger and lock it in place with a nut. Here are a couple of pics:
users.adelphia.net/~lbilling/images/motorcycle/DSCF0340.JPG
users.adelphia.net/~lbilling/images/motorcycle/DSCF0343.JPG
Len
Len
Len
77 KZ 1000 LTD Original Owner
- kz1000ltd
