Leaking from cluth pedal?
  • takuma
  • takuma's Avatar Topic Author
18 Aug 2008 17:49
#232769
Hey guys I just got a 1981 KZ305 and everything has been going great with it but I noticed it is leaking right where the clutch pedal is connected to the engine. Does anyone know what I can/need to do to stop this? Thanks
Re: Leaking from cluth pedal?
18 Aug 2008 18:25
#232775
Clutch pedal? Do you mean the shifter or maybe the clutch release mechanism? Ed
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
18 Aug 2008 18:42
#232782
Have you just recently lubed the chain?
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • takuma
18 Aug 2008 19:54 - 18 Aug 2008 19:55
#232802
I am talking about the shifter.
Yes I did just lube the chain.
Last edit: 18 Aug 2008 19:55 by takuma.
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
19 Aug 2008 15:11 - 19 Aug 2008 15:13
#232956
Sorry for the delay. It's real common for a newly juicy chain to fling the lube off around the front sprocket. It would look just like the leak you're describing.
Been There, Done that!
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Last edit: 19 Aug 2008 15:13 by KZQ.
  • takuma
19 Aug 2008 17:55
#232983
KZCSI
Yes that is exactly what it is. I feel somewhat retarded now but, oh well that's how you learn.
thanks alot.
  • Locozuna
  • Locozuna's Avatar
19 Aug 2008 18:47
#232999
Now that this is over I have been trying to stay out of it but I have to say When I first saw the title of this thread I about died! I still cannot think of it with out gafawing like an idiot. I think my brain stopped dead for a few seconds when I first read it. Thank you....I really needed that! No kidding I needed that laugh!! Thanks! :P :P :P :P :P :P :P :P :P :woohoo:
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
19 Aug 2008 20:05 - 19 Aug 2008 20:06
#233013
No problem Takuma,
I have an Indian with a clutch pedal. I knew what you meant. Like I said I only learned it by running a chain that I had over oiled and run before the excess could drip off.
It can make quite a mess can't it?
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Last edit: 19 Aug 2008 20:06 by KZQ.
