Dreaded oil question....
- Britcheflee
17 Aug 2008 20:05 #232583
by Britcheflee
Dreaded oil question.... was created by Britcheflee
I am going to do an oil change on my KZ650B - the book says put in either 10/40 or 20/50 - the bike now runs good, no knocking or anything and has 30,000 miles. I ride it mainly in good weather - which in CA can be hot. What oil would you go with in this situation.
thank you,
Lee
thank you,
Lee
- Bluemeanie
- Thank you received: 14
17 Aug 2008 20:19 #232585
by Bluemeanie
Replied by Bluemeanie on topic Dreaded oil question....
There have been many threads about what oil everyone uses and why but I also live in SoCal and I have been running 20-50 automotive oil for over 25 years with no problems. My bike has over 53,000mi and am still on the original clutch and the engine runs great. I change my oil every 1,000mi and filter every other change, so the bike has never really seen dirty oil. You can run 10-40wt just fine, I just think that 20-50wt is much better for the high heat we get and works fine with our mild winters. By the way, where in CA are you? We have group rides now and then, interested?
- Britcheflee
17 Aug 2008 21:42 #232592
by Britcheflee
Replied by Britcheflee on topic Dreaded oil question....
I am up in Camino - a few miles above Placerville on Hwy 50 - I would indeed be interested in a group ride.
lee
lee
- bountyhunter
- Thank you received: 337
18 Aug 2008 12:18 #232693
by bountyhunter
Replied by bountyhunter on topic Dreaded oil question....
Britcheflee wrote:
You can put in two quarts of each and get 15 - 45W.I am going to do an oil change on my KZ650B - the book says put in either 10/40 or 20/50 - the bike now runs good, no knocking or anything and has 30,000 miles. I ride it mainly in good weather - which in CA can be hot. What oil would you go with in this situation.
thank you,
Lee
- flht1997
- Thank you received: 2
18 Aug 2008 12:24 #232698
by flht1997
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
Replied by flht1997 on topic Dreaded oil question....
all my bikes have been getting Rotella 15w40 for the past few years, no problems so far.
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
- Thank you received: 2829
18 Aug 2008 12:43 #232707
by 650ed
Replied by 650ed on topic Dreaded oil question....
10W40.
- Justyn
18 Aug 2008 22:56 - 18 Aug 2008 23:00 #232833
by Justyn
1980 750 LTD (kz750h) Wausau, WI
Replied by Justyn on topic Dreaded oil question....
Take the following with about 14 grains of salt.
I've been running 15-40 in all three of my vehicles with zero problems so far. I'm not terribly religious about changing my oil, but I don't let it go too long either 4000-5000 miles. I've yet to run the bike or the car in any kind of cold weather (I live in Wisconsin), but the truck (86 GMC 3/4 ton) did fine if I let it warm up, but that is most likely related to fuel (carb, not FI), not the oil weight. I've yet to see bad oil pressure. The only thing that I will guarantee in this post, is that our winters are far colder than yours (and that our dairy products are better than yours ).
The reason I switched to 15-40, is because that is what they run at my Dad's shop, and I get in and have use of the tools (and generally supplies) for free. What it boils down to is that I pay for a filter only on oil changes.
Like I said, take that advice at your own risk. Oil has been free to me (but cost the business a small amount of money {large diesels using 10 qts plus each, easy for a few to get lost along the way }), and I am no mechanic, not by any stretch, but everyone I've had look at my vehicles has yet to relate an oil related problem other than tired valve seals on the 86 truck. But it's 23 years old, and I don't give a damn if it burns a bit of oil, at least I know it's getting lubed :lol: .
For the record, emissions do not matter on personal vehicles in Wisconsin.
Last edit: 18 Aug 2008 23:00 by Justyn.
