1045cc kit on KZ900 case ???
- Old Man Rock
16 Aug 2008 19:52
Hey all,
1015cc kit, kz900 cylinder bore & hone only. No sleeve or case grinding required, I get it.
1075cc kit, kz900 (sleeved) or kz1000 cylinder bore & hone only. Case grinding required, I get it.
Question...
What is required for the 1045cc kit?
Is this a 1015 cylinder in which case the lower case requires grinding for the cylinder sleeves to fit?
Thansk,
OMR
Question...
Thansk,
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- APE Jay
Re: 1045cc kit on KZ900 case ???
17 Aug 2008 08:58
Don't think you can put the 1045 in a 902 sleeve and have enough cylinder wall left.
Jay
Jay
- Old Man Rock
17 Aug 2008 10:35
Damn, that's what I was afraid of... Thanks.
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- PLUMMEN
17 Aug 2008 17:58
im not a fan of the 1015 in stock 900 sleeves either
- Old Man Rock
17 Aug 2008 19:54
Plummen, 1015 or 1045 is what your referring to?
I'm fairly confident that is a miss print but after what I've been going through lately (Florida vendors) I'm somewhat paranoid....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- PLUMMEN
18 Aug 2008 11:28
1015 in stock 900 sleeves leaves very little meat to seal the rings,same as 1105 in stock 1000 sleeves(dont tell Sandy i said that!:laugh: )
- Old Man Rock
18 Aug 2008 13:19 - 18 Aug 2008 13:21
In measuring the sleeves, I believe they had been updated to kz1000 specs... Sleeve opening measured at 69.5mm.
I guess I should measure the thickness of the sleeve as well...
Again, Florida hates me..... :pinch:
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 18 Aug 2008 13:21 by Old Man Rock.
- PLUMMEN
19 Aug 2008 09:31
its been a while since ive seen a stock bore 1015 but im thinking the bore should be 70mm .look at the bottem of the sleeves,is there still a chamfer in bottem of sleeves?if not im thinking those are 903 sleeves
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
19 Aug 2008 10:03 - 19 Aug 2008 10:09
PLUMMEN wrote:
You are correct. 1015 sleeves are 70mm. 998 sleeves ('81+) are 69.5mm. Are you sure you don't have '81+ jugs? What does the displacement stamp on the side of the cyls say? 1.015L? .998L? .903L?
West Linn, OR
Last edit: 19 Aug 2008 10:09 by Skyman.
- Old Man Rock
19 Aug 2008 10:28
"What does the displacement stamp on the side of the cyls say? 1.015L? .998L? .903L? "
The cylinder is 903cm if this is what you asked about.
In measuring the pistons, 70mm.
Bores 69.5mm... See other posting on this.
kzrider.com/index.php?option=com_kunena&...ew&id=232388&catid=2
1015 should be 70mm
1045 should be 71mm
1075 should be 72mm
Basically they sent me the wrong pistons for what I ordered... Same time, the 1015 pistons wouldn;t work either for the bore is only 69.5mm.
I asked this for if they already had a 1045 kit in stock, what would be required to go this route.
Thanks all,
OMR
1015 should be 70mm
1045 should be 71mm
1075 should be 72mm
Thanks all,
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- PLUMMEN
20 Aug 2008 04:46
the 1045 would require 1015 sleeves,your block would need to be bored to fit the sleeves.sounds like a major pain in the ass youve stumbled into here!
- Old Man Rock
20 Aug 2008 06:00sounds like a major pain in the ass you've stumbled into here!
Somewhat unbelievable I know but true just the same. Going on two months now! It's truly mind blowing amazing that this can even be occurring in this manner... Truly SUCKS! :pinch:
Again, Florida hates me!... Poor OMR!
The cylinder and pistons have been sent back. Hopefully Overstock will do the right thing and insure the cylinder is bored to spec (clean and true bore/hone, no ovals) and the new 1015cc pistons will be sent back to me.
Then I can finally get this project going again...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
