Help Stripped head
- 79KZNinja
16 Aug 2008 16:26 #232384
by 79KZNinja
Help Stripped head was created by 79KZNinja
I have a 79 KZ650 C3 and I was in the process of taking out the starter clutch to repair it. I was trying to take the oil pump out and loosen the 3 bolts on the bearing stop (they are phillips heads and are staked) I used a manual impact driver and it striped the head) any ideas? I am talking about the one on the right side below the clutch.
- cmmman
16 Aug 2008 16:53 #232387
by cmmman
1977 KZ650B, modified.
Replied by cmmman on topic Help Stripped head
Maybe you could try a small cold chisel and a hammer to break it loose.
- kz200noob
16 Aug 2008 22:38 #232424
by kz200noob
Replied by kz200noob on topic Help Stripped head
i usually take a larger star bit and hammer it into the screw head making a inpressing of the star and the hammering will loosen it up. or there are special tools like the grab it that pulls out stripped screws.
- birchwood82
- Hello from Northern Wisconsin
17 Aug 2008 00:27 - 17 Aug 2008 00:31 #232432
by birchwood82
1981 KZ 1100 B1 GPz
1982 Yamaha Virago
Birchwood Wisconsin
Replied by birchwood82 on topic Help Stripped head
Could you possibily do this, find a drill bit slighly smaller then screw head, now the key here is the next statement slowly in reverse drill the head till its weak enough to be removed from what ever its holding, now I say reverse and it is a pain but it works and it will not bite and wreck cover or what ever its holding like it could in forward.( and does I know, its faster in forward but if it bites in you WILL wreck both pieces trust me I KNOW!!!!).
1981 KZ 1100 B1 GPz
1982 Yamaha Virago
Birchwood Wisconsin
Last edit: 17 Aug 2008 00:31 by birchwood82.
