- Thank you received: 2098
higher top speed
23 Aug 2008 08:15 #233571
by Patton
Replied by Patton on topic higher top speed
On the large fours with stock sprockets barely pulling redline in top gear, adding one tooth to the countershaft sprocket reduces the rpm at any given road speed (for a more "relaxed" feel) at the expense of reduced acceleration; but generally does not result in a higher attainable top road speed (likely won't pull redline with the taller gearing).
- OKC_Kent
25 Aug 2008 17:17 #233975
by OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Replied by OKC_Kent on topic higher top speed
How are you primarily using the 200? If your top speed is 60, what will 70 do for you? Are you thinking about taking it on the interstate or city freeways?
Oklahoma City, OK
- HansNOR
26 Aug 2008 03:40 - 26 Aug 2008 05:27 #234018
by HansNOR
o 198x Kawasaki GPZ 750 (year will be updated)
x 1981 Kawasaki KZ 650 SR
Replied by HansNOR on topic higher top speed
realized my posting was too much of a thread stealer
Last edit: 26 Aug 2008 05:27 by HansNOR. Reason: oups
