higher top speed
- kz200noob
- Royal1MC
- Is it just me, or is it just great to be on a KZ
www.jtsprockets.com/fileadmin/files/jtgearratio.pdf
*1980 Z1-R (current))
*1978 KZ1000 LTD w/ Z1-R frnt end (sold)
*1977 KZ650 B1 (sold)
Los Angeles, CA
- steell
So, are you hitting the redline on the tach in top gear?
- kz200noob
- Thank you received: 2829
- 79MKII
- Love Them Kaws!
- Thank you received: 43
The Kaw List:
- kz200noob
- PLUMMEN
- Thank you received: 104
- kz200noob
- Thank you received: 2098
Changing sprockets isn't going to help any unless you are hitting redline in top gear now.
I'm with steell on this one. And betting my nickel that taller gearing will either equal or result in a lower top speed, accompanied by noticeably reduced acceleration.
In other words, taking longer to reach the same or a lower top speed.
At least that's the way it often works out on the large fours which usually attain about the same top speed in either 4th or 5th gear, using stock sprocket sizes.
Good Luck! I'll be glad to lose another nickel!
Edit -- Imo, the "best" gearing is when the engine will just barely pull redline in top gear.
- bountyhunter
- Thank you received: 337
As you go past about 65 mph on a bike without a streamlined fairing, wind drag starts to hit like a brick wall. A small engine with low power and torque is going to flatten into that wall.
- 79MKII
- Love Them Kaws!
Adding a tooth or 2 to the front will change the speed across the entire RPM range. Of course, you can go too far with the drive ratio and not have enough power to pull it, but is a sprocket with 2 more teeth going to put us there??
Even my KL250 has plenty of power to support a mild gearing change. I've never dealt with a KZ as small as a 200, so maybe that's why I'm so surprised here.
The Kaw List:
