750 motor in a '78 KZ650 frame?
- steell
21 Aug 2008 03:41 #233231
by steell
Replied by steell on topic 750 motor in a '78 KZ650 frame?
That's why we used the 650 charging system on the 83 GPz750 motor, it was easier than messing with the wiring
Stock gearing on a 83 GPz750 is 15/38 with a 630 chain.
We used 18/45 with a 530 chain, but GPzInfested thinks a 17/38 might be better (we have both 17 and 18).
If you want to use 530 chain, then you will need a 6mm offset front sprocket since the stock 630 front sprocket has a 6mm offset. The 83-85 GPz750 motors are the only 750 that require an offset sprocket with a stock rear wheel.
The 83-85 GPz750's use a large front sprocket because the have a large diameter swingarm pivot (aluminum), with the stock steel 650 swingarm you could use smaller front and rear sprockets since you won't have the clearance issue.
6mm offset 530 sprockets are available at www.afam.co.jp/E/index2.htm , use the one that's listed for the Z1/Z2/750FX/Z1R.
- grinch77
21 Aug 2008 13:33 - 21 Aug 2008 13:34 #233303
by grinch77
1978 KZ650\'82 KZ750 motor
1991 SE-R
Coweta,OK
Replied by grinch77 on topic 750 motor in a '78 KZ650 frame?
My motor came out of a 81 or 82 KZ750 so there is no need for the offset sprocket then right?
1991 SE-R
Coweta,OK
Last edit: 21 Aug 2008 13:34 by grinch77.
- steell
21 Aug 2008 18:16 - 21 Aug 2008 18:22 #233355
by steell
grinch77 wrote:
Not unless you are running a big tire on the rear
I had to use an offset sprocket on my 80 KZ750E to get past the 160/55/17 tire that's on it.
Crap, got confused in an earlier post and thought you were installing a 83 GPz750 motor
You can just use the 650 chain and sprockets on your 750 motor, stock 750 gearing is 13/33 630 chain.
Last edit: 21 Aug 2008 18:22 by steell.
- grinch77
22 Aug 2008 06:43 #233433
by grinch77
1991 SE-R
Coweta,OK
Well everything is going real smooth so far need to round up some new air filters for the carbs then I'll be good to go.
1991 SE-R
Coweta,OK
- steell
22 Aug 2008 11:07 #233475
by steell
grinch77 wrote:
That's good to hear
If you want to use a stock airbox and filter, the KZ750 airbox will fit in the 650 frame for the KZ750 motor, and for anyone using the 83-85 GPz750 motor, the GPz750 airbox will fit also.
May have to fasten them in with wire ties or something though, I don't think the bolt holes line up.
That's good to hear
- grinch77
22 Aug 2008 19:16 - 22 Aug 2008 19:18 #233527
by grinch77
1991 SE-R
Coweta,OK
Steell thank you for the help I really appreciate all the help you have given.Hopefully this will be the last question.
It looks like 750 carbs are set up for a single throttle cable is this correct and what is needed to swap from a dual cable set up to single?
On my gas tank I have the main fuel line coming off and another line witch is a vacuum I think do I hook up the vacuum line to one of the vacuum holes that are on the top side of the carbs?Also the two lines that come down in between the 1 and 2 and the 3 and 4 carbs are just puke tubes?
Again thank you for spoon feeding me all the info for the questions I asked.
Craig
Craig
1991 SE-R
Coweta,OK
Last edit: 22 Aug 2008 19:18 by grinch77.
- steell
22 Aug 2008 21:00 #233533
by steell
Now you got me
We used a GPZ750 motor, along with the GPz750's Mikuni carbs, and the GPz750 throttle cable, and my 750E doesn't have carbs since I'm going with EFI on that one.
I think I'd probably tie all the vacuum ports together, then tee into that line for the petcock. We had to go with a Pingle petcock because the stock one hit the top of the Mikuni carbs and wouldn't let the tank set down like it's supposed to.
