- Thank you received: 1
Adding an External Oil Cooler
- iandz500
I was wondering how difficult it is to fit an external oil cooler?
Would the cases need to be be drilled and tapped or could i come off existing plugs/feeds somehow?
I believe the engine is very similar to the KZ550.
Thanks
Ian
Bikes: 1960 lambretta Li125 sold; 2001 Honda CG125 sold; 2006 Yamaha FZ6 sold; 1980 Kawasaki Z500 sold; 1967 BSA Bantam D10; 2008 Aprilia Shiver sold; 2010 KTM Duke 690R; 1954 BSA Bantam; 1980ish Kawasaki Z200
- bill_wilcox100
- Thank you received: 5
Best of success.
PS
Do us a fovour and add your year, model and location to your signature for the best responses.
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
- iandz500
it may infact be longer than 30 minutes riding that casues the light to come on to, perhaps 3/4 hour is more realistic!!
- bill_wilcox100
I wonder if your oil pressure switch is out of calibration and turning on when the oil pressure is actually still in specification.
Can you try a known working oil pressure switch.
Best of success.
Upgrades:
Montreal, Canada
- Thank you received: 2098
Problem might be a clogged oil pump pick-up screen, which can impede volume of oil flow into the pump.
Good Luck!
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- SPARKY47
- 1980 KZ500 B2
1980 KZ500 B2
- iandz500
Adding oil cooler sometimes worsens early oil light problem, because of additional pumping requirements.
Good Luck!
can i get to that without stripping the engine?
i've tried 10w40, 10w50 and 20w50
- SPARKY47
- 1980 KZ500 B2
Oil wise , try Shell Rimula 10 40.
Have you got a manual?
I'm in Lichfield. Staffs.
And I've got a 500 too:woohoo:
1980 KZ500 B2
- steve3408
1980 KZ1000 A4(bought new),1979 KZ1000 MKII(bought new),1978 KZ1000 A (sold)1979 KZ1000 B LTD (sold)1976 KZ900 LTD (sold)1978 KZ750 twin (sold)
- iandz500
You can take the oil pan off with the lump in, you'll need an impact driver if you want to get the oil pump off.
yeah i've got a haynes manual.
will try taking that off and cleaning it all out, it needs an oil change again,
do i need a new gasketfor the pan?
i'm in aylesbury bucks by the way
- SPARKY47
- 1980 KZ500 B2
From what I've learnt, oil change every 2500 miles.+filter.
1980 KZ500 B2
