Starting Problems
  • bubbap
  • Topic Author
  • Ride it like you stole it!
11 Aug 2008 09:18 #231363 by bubbap
Starting Problems was created by bubbap
I have a problem with my 79 kz650. She doesn't want to start without cranking the motor over for several seconds with full choke. It acts like its not getting enough fuel to start. I have been running the bike for the last month now after a complete restoration. It has been running fine I finally got all the right valve shims in place. The only thing I changed right before this started was the no. 1 piston intake shim. It runs great once started but still does not want to start after running a while. I took it on a road trip 1:30 each way with no problems except the starting.
I don't like running the starter that long so I try to kick it as much as I can to start. Like I said this is after a complete rebuild and I am still working out the bugs nothing serious just little things.
1979 KZ650, Mac 4-2 exhaust. Restored after 25 years of sitting. Dyna elec coils, ignition. As old as I am, been in the family since new.
11 Aug 2008 09:29 #231364 by MFolks
Replied by MFolks on topic Starting Problems
Sounds like you need to get a new ignition system. The Dyna S has been used on several older Kawasaki's with great success. See them at www.dynaonline.com
The website that "wired George" runs has information about a relay modification that will also improve the combustion process in your engine by bypassing the corrosion in the wiring.
His website with the diagrams and parts is www.wgcarbs.com
He also runs a carb rebuilding service for motorcycles out of Texas and does wonderful things to the carbs.
  • bubbap
  • Topic Author
11 Aug 2008 13:10 #231391 by bubbap
Replied by bubbap on topic Starting Problems
I am running a brand new Dyna Ignition system with electronic ignition, dyna coils.
I have also gone through the entire wiring harness and replaced any questionable wires or connectors. She runs great after starting. I just don't understand why its hard to start.
11 Aug 2008 13:47 #231396 by BSKZ650
Replied by BSKZ650 on topic Starting Problems
I havent looked on the break down, but dosent that year have the vacum petcock? you need to start it in the prime location, then change to on.
I may be all wet here but what else is new
77 ltd1000, current rider
76 kz900, just waiting
11 Aug 2008 14:33 #231404 by MFolks
Like the man said maybe vacuum petcock problems may be the answer.
For four cycle engines to run/operate you need 1.Fuel 2.Air 3.Compression and 4.Ignition. Any one of these four go missing and it will not operate.
11 Aug 2008 19:33 #231455 by Patton
Replied by Patton on topic Starting Problems
If not already doing ---
When cranking with choke on, do not touch the throttle. The choke circuit is designed to operate with the throttle slides in the full down position.
Would also use strobe-type timing light to check ignition timing and proper operation of the advancer as rpm is varied.
Good Luck! :)
11 Aug 2008 21:24 #231485 by Ashbane
Replied by Ashbane on topic Starting Problems
tag for later reference... ;)
1976 KZ750 B1 Twin
  • bubbap
  • Topic Author
12 Aug 2008 08:43 #231569 by bubbap
I did some work on the bike last night, the petcock is working great in all positions. Timing is set with a dial advance timing light. advance is working properly
In order to start the bike I have to give some throttle or it will just keep cranking. Spark is good. I am going to clearance the shims again to see if I missed something. Any ideas are greatly appreciated.
I also vacuum tested each carb, they are all set equally. I starting to wonder if my cylinders are leaking too much?
12 Aug 2008 08:55 - 12 Aug 2008 08:56 #231574 by bill_wilcox100
Replied by bill_wilcox100 on topic Starting Problems
Still not sure your ignition wiring is good. Can you do the following simple test. With ignition switch on:
1) Measure the voltage across the battery terminals.
2) Measure the voltabe across the battery (-) terminal and the Coil (+) input.
3) What are the readings?
This will tell you what your ignition wire, connector and switch losses are.
Best of success. :)
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Last edit: 12 Aug 2008 08:56 by bill_wilcox100.
12 Aug 2008 09:59 #231594 by Patton
Carb enrichener circuit may have blockage and need cleaning. :)
  • bubbap
  • Topic Author
12 Aug 2008 11:34 #231607 by bubbap
Voltage across battery is 12.18 at the coils it is 9.15 each.
12 Aug 2008 11:39 #231608 by MFolks
Sounds like a cosiderable voltage drop through the wiring,and the "Wire George" relay mdification will help.
Go to www.wgcarbs.com for the info.
