If I remove the baffles, will I have to rejet?
- slowman
10 Aug 2008 17:35 #231227
by slowman
1979 Kawasaki KZ1000 LTD
The only thing better than the sound of a carburettor opening is the sound of 4 carburettors opening simultaneously!
If I remove the baffles, will I have to rejet? was created by slowman
'79 KZ1000
The bike has airpods right now. I'm not sure if the previous owner rejetted after the airpods were installed. Everything else is stock.
So will I have to rejet if I remove the stock baffles? What would happen if I don't (lean/rich)?
Thanks!
Thanks!
- steve3408
10 Aug 2008 17:47 - 10 Aug 2008 17:51 #231231
by steve3408
1980 KZ1000 A4(bought new),1979 KZ1000 MKII(bought new),1978 KZ1000 A (sold)1979 KZ1000 B LTD (sold)1976 KZ900 LTD (sold)1978 KZ750 twin (sold)
Replied by steve3408 on topic If I remove the baffles, will I have to rejet?
Pull the baffles and see how it does,if it runs lean (pipes turn blue) just enrichen it a little.You may have to re jet it anyway,but that would give you an idea if it only needs a little or none at all.Probably will with those pods tho.
So why do you want to remove the baffles for??..make it louder?...thats about all it will accomplish.
Last edit: 10 Aug 2008 17:51 by steve3408.
- Thank you received: 2098
10 Aug 2008 17:58 #231233
by Patton
Replied by Patton on topic If I remove the baffles, will I have to rejet?
slowman wrote:
Removing baffles may result in leaner operation, especially at higher rpm.
Best indication for proper mainjet size is plug reading after a high speed throttle chop (cut ignition at same time and bring to stop). To assure valid plug reading, should be done after assuring correct valve clearances and good quality spark with correct ignition timing, and clean free-breathing properly oiled pods.
Might be able to compensate for any mixture change needed in the pilot circuit (without replacing the pilot jets) by adjusting the side located pilot air screw (turn in clockwise to enrichen the mixture, by reducing air OR turn out counterclockwise for leaner mixture, which allows more air).
Good Luck!
'79 KZ1000
Thanks!
Good Luck!
- slowman
10 Aug 2008 19:15 #231250
by slowman
Replied by slowman on topic If I remove the baffles, will I have to rejet?
Thanks for the insight! This is something I'll probably experiment with next weekend. I only wish I had the time to during the week.
10 Aug 2008 19:40 #231255
by Patton
As known, the carb pilot circuit mostly governs the lower rpm range of operation (from idle up to about the first 1/4 of throttle opening).
When doing the high speed throttle chop, usually the bike is pulled to a stop in a safe location off the road so the plugs may be removed and inspected. And the plugs are HOT. Here's a tip -- remember to carry along suitable plug removal tool, and a short length of rubber hose which fits snugly over the plug to allow easy removal and replacement of the plugs without burning fingers.
