Factory exhaust 4 82ltd1000
  • Buda
  • Buda's Avatar Topic Author
10 Aug 2008 12:45
#231175
I just bought a 4 into 1 for my bike, when i took the factory 2 into 2 i found a crack where the 1st and 2nd pipes come together. Is this something worth fixing or is it junk. Is it something anybody needs.
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
  • littlemanonbigbike
  • littlemanonbigbike's Avatar
Re: Factory exhaust 4 82ltd1000
10 Aug 2008 13:14
#231181
What do you want for it? I have been looking for one as I have a 4 into 1 but would like to go back to a 2-2. PM me if you like.
1982 1100 Spectre
Various other toys
10 Aug 2008 17:19 - 10 Aug 2008 17:26
#231223
This diagram is from www.kawasaki.com
[click on image for larger view]
Appears the "Y" connection between header and muffler is built as a permanent part of the muffler.
Many cracks are readily repairable by a competent welder, in this case probably brazed, at nominal expense. And here, perhaps the repair would be hidden by the outside "appearance" cover.
Could the damage be more specifically described? With possibly a photo?
Would suggest taking the parts to a welder for advice.
Good Luck! :)
Last edit: 10 Aug 2008 17:26 by Patton.
