Valve question
- kz750ohio
08 Aug 2008 20:52 #230931
by kz750ohio
1982 kawasaki kz750 with mikuni carbs bs34, stock everything else.
Valve question was created by kz750ohio
Well my old girl decided to quit on me. The automatic cam chain tensioner stuck open and the chain broke on me. I got lucky and only bent one valve and did not damage any pistons. I noticed though, I have a couple of exhaust valves that are leaking a little. I was considering replacing the exhaust valves and the one intake. The question I have is on the valve brand. Is there a difference between vesrah valve and kawasaki oem or are they about the same.
I will also install new guides from ape all the way around and the tensioner guides because of the wear. My old girl only has 6900 miles on her so any input would be appreciated.
cheers,
max
cheers,
max
- steell
08 Aug 2008 21:50 #230933
by steell
Replied by steell on topic Valve question
All this in only 6900 miles? :woohoo: X 2!!
Now, 69,000 miles I could maybe understand.
I'm just to dumbfounded to make a coherent reply right now :ohmy:
- APE Jay
- Banned
- Thank you received: 58
08 Aug 2008 22:16 #230934
by APE Jay
Replied by APE Jay on topic Valve question
In most cases, Veshrah sources parts from the same manufacturers that the oems use.
Jay
Jay
- kz750ohio
09 Aug 2008 09:24 #230982
by kz750ohio
Replied by kz750ohio on topic Valve question
thanks jay....on to the other guy. yes it is disappointing. but I figured since she set up for so long things no matter how unusual will come up from time to time. plus I consider her to be a learning project.
thanks everyone.
thanks everyone.
- mtkawboy
- Thank you received: 16
09 Aug 2008 09:27 #230987
by mtkawboy
Replied by mtkawboy on topic Valve question
The factory Kawasaki valve will be about 6 times or more as expensive as the Vesrah
- bountyhunter
- Thank you received: 337
09 Aug 2008 13:07 - 09 Aug 2008 13:07 #231020
by bountyhunter
Replied by bountyhunter on topic Valve question
mtkawboy wrote:
Amen. I got a set of new Vesrah valves for my twin off ebay for about $10 each. Look for RustyRiders LLC as they seem to always be selling NOS valves for old Kawis at a ridiculously low price.
Last edit: 09 Aug 2008 13:07 by bountyhunter.
