  • H1Vindicator
  • H1Vindicator's Avatar Topic Author
07 Aug 2008 07:00 - 20 Feb 2013 18:55
#230634
Last edit: 20 Feb 2013 18:55 by H1Vindicator.
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
Re: Rerouting the clutch cable
07 Aug 2008 07:37
#230636
If nothing else,slacken off the adjustment behind the small cover,on the clutch cover itself.
Gives you a reason to check the adjustment anyway.:)
1977 KZ1000 A-1
  • coppertales
  • coppertales's Avatar
07 Aug 2008 08:37
#230643
If your cable has the adjustment in the middle of the cable down by the exhaust pipe, you can loosen it there and at the lever to give you enough slack to remove the cable from the lever. What Sandy says is good advice too..........chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
