100 hp KZ650
  • Paling1
  • Paling1's Avatar
Re: 100 hp KZ650
12 Aug 2008 10:57
#231604
Just for reference, here's a pic from the combustionchamber of a 2002 Kawaski ZR-7:
It still has the same design as the GPZ heads...
I bought this head a while ago, and I'm planning on doing some mild porting and skimming, and putting it on my KZ700.
KZ700-A1 (1984)
525 chain conversion; Dyna 2,2 ohm coils; Taylor plugwires; Stainless steel ZR-7 exhaust ; Remus muffler.
Plans: GPZ cams, ported head, 17 inch wheels, EFI....
  • steell
  • steell's Avatar
Re: 100 hp KZ650
12 Aug 2008 12:30
#231617
Yep, looks just like the 83-85 GPz750 head.
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
Re: 100 hp KZ650
14 Aug 2008 13:43
#232032
You don't need to do anything to a KZ650 to get 100rwhp, because Kawasaki did it all for you.
It's called the GPz750 turbo, and 100hp is where it starts...:)
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
  • steell
  • steell's Avatar
Re: 100 hp KZ650
14 Aug 2008 17:31
#232052
Yes you do, you have to locate then buy the GPz750 Turbo :D
Or let your Nephew buy one and park it in your garage (worked for me) :P
  • Z1109R Fin
  • Z1109R Fin's Avatar
Re: 100 hp KZ650
15 Aug 2008 05:46
#232134
:P
1 for sale here for only 5100€.....
Z1000R ´83...Slightly modified...
  • purgeraptor
  • purgeraptor's Avatar
Re: 100 hp KZ650
05 Oct 2008 04:37 - 06 Oct 2008 09:28
#240210
My standard z650B3 (apart from Harris 4 into 1 and pods with bigger jets) is at last up and running :)
It goes OK apart from worn bores/rings burning too much oil due to high mileage.
Rather than go for one size over re-bore, I like the idea of freshening it up with Z750 barrels bored to take a Wiseco 810 kit.
I'm not after top end power, but mainly want more mid-range torque.
From this thread it looks like I'll have to open up the crank case openings to slide the bigger z750 liners in.
How much work is involved in this? Machine shop or DIY dremmel job?
Also, can I just bolt my 650 head back on to the z750 810 block with the Wiseco pistons? Any issues with piston/valve/head clearance?
Final question, will the standard carbs be big enough or will they restrict the max torque?
Any answers gratefully received :)
Last edit: 06 Oct 2008 09:28 by purgeraptor. Reason: spelling
  • kzr750r1
  • kzr750r1's Avatar
Re: 100 hp KZ650
05 Oct 2008 14:42
#240274
When the storage box is free I'll post a picture of my 82 GPz 750 head just for the sake of documenting it.
If I have the time I'll measure the cc of the combustion chamber.
Not all that impressed with the midrange on my current setup. Turns out the Zypher went with a mild state of tune and it requires some tweaks to get it up to my expectations.
Compression is 9.5.1? Have to go look at the book again for a spec.
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: 100 hp KZ650
05 Oct 2008 15:02
#240276
I saw an 85 gpzturbo in Toronto Can., fri . 1 owner $4500. 47000 miles. Looked very good too. Very clean.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
Re: 100 hp KZ650
05 Oct 2008 18:35 - 05 Oct 2008 18:41
#240306
I really like the idea of turbo. Can't wait to get my bike done over the winter. Sitting in the garage all lonely with in pieces just waiting to be taken apart to get started with all the details.
79 LTD B3
Last edit: 05 Oct 2008 18:41 by saxjonz.
