Thanks for the rambling. Always good to get different perspectives and benefit from others experiences. If money not critical....turbo cams better than stockers ?
quote]
I think it will largely depend on how crazy you go with the motor i.e. what displacement and compression ratio you end up with and what kinda boost you are pumping. I think that for just street use - you won't see much if any real performance advantage going with a turbo/blower grind.I think this is especially true if you don't have the chassis and especially the rear end setup (i.e. swing arm/wheel/tire)to get any performance gains to the ground. Any gains from a performance cam just go up in smoke from tire spin or the frame is just too wimpy to handle safely and you have to back off the throttle.
Anyway - just some thoughts
