1982 750 Spectre
- mitch.dail
06 Aug 2008 11:03 #230517
by mitch.dail
1982 750 Spectre was created by mitch.dail
Will running this bike without the airbox cause it to die at high rpms (5400rpm)? This bike was just gone thru and everything checks out good. The carbs have been rebuilt. It idles great and cranks easy. When you rev it up it dies at around 5400rpms. The air box has not been installed yet. This is a bike that I am considering buying from a friend.
- The Milkman
- Thank you received: 194
06 Aug 2008 11:39 #230522
by The Milkman
Replied by The Milkman on topic 1982 750 Spectre
It could be as simple as a partially plugged fuel filter, if one is installed. If one isn't installed the carbs probably need a thorough cleaning and install that fuel filter. Also, if there is no filter, I have seen the tubes that run between the carbs get FULL of so much crap that I could barely get a round toothpick through them!!!!!
- bountyhunter
- Thank you received: 337
06 Aug 2008 11:44 #230523
by bountyhunter
Replied by bountyhunter on topic 1982 750 Spectre
mitch.dail wrote:
I think it might. It could be running so lean at wide throttle that it stops getting enough fuel to pull hard.Will running this bike without the airbox cause it to die at high rpms (5400rpm)?
- kzwolfsr
- Thank you received: 16
06 Aug 2008 12:32 #230540
by kzwolfsr
Original man of the Caribbean
Replied by kzwolfsr on topic 1982 750 Spectre
Bounty has a point. Its lean plus you are sucking in all kinds of bugs into the engine. And it would be wise to get a new fuel filter and if the bike doesn't have one, get one. It decreases the amount of times you will need a carb cleanout. No offence Wg!
- Locozuna
06 Aug 2008 15:18 #230555
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Replied by Locozuna on topic 1982 750 Spectre
If it is set up for an air box and filter (meaning jetted right and adjusted) then she will certainly not run correctly without them. Thats why you do that. But how did it get adjusted without the airbox and filter? I can see the jets since you would most likely use stock jets if you intend to use the orig setup. You might have to do a little adjusting when you get the box on. But I think what you are describing has to do with the missing airbox and filter.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- mitch.dail
10 Aug 2008 20:07 #231264
by mitch.dail
Replied by mitch.dail on topic 1982 750 Spectre
Thanks to everyone for all the help. Reassembled the air box and now this 1982 kz750-n runs like new.
