Newbie clutch help kz400 78
- redline
I've taken my clutch cable off because it broke, i got a new cable but in the mean time i lost a part from the clutch internals, what im' trying to describe is there is a little round circle with 3 ball bearings, and the ball bearing piece is in the middle of the 2 female parts that hold the ball bearing piece. I"m looking for the part that has the notch in it, to seat it's self properly.
I know this is very very vague.. any help would be appreciated. Looking for the part name or diagram, so i can confirm and try to source this part out.
cheers
- Thank you received: 2098
Wondering if some one can help me determine the name of the part i need, i've looked at the parts diagram but dont seem to see it there? Before i start pardon, the lack of correct terms of the parts im' about to describe
cheers
Hello, redline! Welcome to to KZR forum. We're glad you're here!
Here for reference are the '78KZ400 clutch parts diagram and pn's from kawasaki.com
Good Luck!
[click on image to enlarge view]
Item Part Number Part Name Quantity Remarks
1 318B0800 NUT 8MM 1
2 92009-1009 SCREW,SLOTTED,8M/M 1
3 13119-1003 CAM,RELEASE,CLUTCH 1
4 92045-1001 BEARING,BALL,CLUTCH 1
5 92049-1003 OIL SEAL,CLUTCH RELES 1
6 13102-1004 RELEASE, CLUTCH 1
7 550D1615 PIN COTTER 1.6X15 1
8 92081-1058 SPRING,CLUTCH RETURN 1
9 13116-1017 ROD,PUSH,CLUTCH 1
10 600A1200 BALL STEEL 3/8' 1
11 13081-1019 CLUTCH-ASSY 1
12 480J3800 CIRCLIP, 38MM 1
13 610A0606 PIN, DOWELL, 6X6 1
14 59051-1001 GEAR,OIL PUMP,34T 1
15 13095-1008 HOUSING,CLUTCH 1
16 92022-288 WASHER,CLUTCH THRUST 1
17 13087-040 HUB,CLUTCH 1
18 13088-1001 PLATE,FRICTION 6
19 13089-026 PLATE,CLUTCH STEEL 5
20 13116-029 PUSHER,CLTCH SPRG PLT 1
21 13187-1003 PLATE,CLUTCH SPRING 1
22 92081-1033 SPRING,CLUTCH 4
23 92001-1066 BOLT,CLUTCH SPR FITT 4
24 13121-030 SPROCKET,PRIMARY 1
25 480J3000 CIRCLIP,30MM 1
26 13122-005 CHAIN,PRIMARY DRIVE 1
- redline
thanks
now question is i wonder if the local shop can get this for me.
