81 kz1000 low compression
- tyhoppy
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- Thank you received: 2098
I have a 1981 KZ1000 which has sat for a few years that I just purchased. The bike is really lazy in the lower RPMs. I automatically though low compression because of that, plus the way it starts. Starts way low in the rpm range and takes a little while to rev up and idle. I did the compression check and from left to right compression is 100, 80, 30, 100. When doing the oil test on the one with 30 it only goes up to about 60. Does this mean it's a valve? The bike has sat for 2 years so is a sticky valve a possibility? Previous owner guarantees that it had no loss of power when parked and that anything wrong with it happened during storage. Any suggestions on what to do to diagnose this problem? Thanks.
If not already done, would check valve clearances and adjust as necessary by re-shimming to factory specs. Then perform compression test again (holding throttle wide open during testing).
Good Luck!
- steell
Having done a "bunch" of compression tests, the above says it's not rings.
I assume you did the test with oil on the other cylinders and they all showed about the same increase? I hope so, because they are all real low.
A leakdown test is a much better way of diagnosing the problem, but you still need to check/adjust the valves before doing anything else.
You did have the throttle wide open during the test, right? It makes a huge difference.
- tyhoppy
Yes throttle was wide open. what's the easiest way of taking the valve cover off... doesn't look like enough room between the frame and the cams. Also, anyone know the specs that the clearances should be? I ordered a manual but it's not here yet. Thanks.
.002 - .004 inch (.05 - .10 mm)
Remove fuel tank and all sparkplug caps and all valve cover bolts. Gently manuever and wiggle valve cover between the frame and engine. It's a snug fit, but should pull free without having to loosen any other parts.
Good Luck!
- bountyhunter
- Thank you received: 337
I wonder if it's possible fuel could have seeped down and into the intake and gummed up some of the valve seats? If it sat that long, the gas would have turned to varnish like glue.
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
Good Luck!
You can also buy some more space by removing the coil on the side you want to pull the cover out on.
West Linn, OR
- tyhoppy
So both the intake and exhaust valve clearances should be .002 - .oo4 inch?
Yes. All the same.
- Sandy
- Fly High,Tony
- Thank you received: 13
1977 KZ1000 A-1
- wiredgeorge
Your valves either lack clearance or the top end needs rebuilding. I can't imagine this bike running much at all with two cylinder down that far (80/30) but I would definitely adjust valve clearances before yanking the top end. A sticky or bent valve is a possibility. Even though the rings MAY be OK based on your oil compression check, I would consider removing the pistons and measuring the cylinder bores (get a manual) and piston diameter and checking to see if the clearance was within spec. If so, hone and install new rings while you go through the cylinder head.
