- Thank you received: 2829
HELP! Need Piece of Exhaust Pipe
03 Aug 2008 15:53 #229912
by 650ed
HELP! Need Piece of Exhaust Pipe was created by 650ed
The weld on one of the little brackets that holds the "muffler cover" on the exhaust of my my '77 KZ650 broke and the bracket is gone. Does anyone have an old exhaust system (from a KZ650 or other model with the same bracket) that can be cannibalized? I'm interested if someone can just cut the section of pipe out so I can remove the bracket and weld in on my bike. My email is earold@hotmail.com Pictures below show where bracket fell off, general location on pipe, and photo of remaining bracket like the one I need. Please let me know if you can help. Thanks, Ed
- cmmman
03 Aug 2008 18:31 #229957
by cmmman
1977 KZ650B, modified.
Replied by cmmman on topic HELP! Need Piece of Exhaust Pipe
If you have a welder that would be pretty easy to make with a nut welded to a strip of sheet metal.
- Virii
- I like cheese
- Thank you received: 1
03 Aug 2008 18:42 #229958
by Virii
Tess: 1977 KZ650-C1. VM24, 97.5/15/3rd. Dyna-S. Stock exhaust, coil mod performed, BR7EIX.
Angel: 1982 GPz550. Stock. DR8EIX.
Replied by Virii on topic HELP! Need Piece of Exhaust Pipe
Plumbing clamps or strapping from the hardware store?
- RonKZ650
- Thank you received: 240
04 Aug 2008 07:09 #230043
by RonKZ650
Replied by RonKZ650 on topic HELP! Need Piece of Exhaust Pipe
On the Kawasaki parts fiche they have a service bulletin from 9-79 that said to use a cover from a KZ650D SR model if this happens. They clamp on instead of screw on. This is how they handled the problem under warranty. Another option to consider.
- Mark Wing
- Thank you received: 22
04 Aug 2008 17:44 #230195
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic HELP! Need Piece of Exhaust Pipe
I have a pair I can cut lose tomorrow if you'd like. Just pm your address.
Mark
Mark
Yorba Linda Cal.
05 Aug 2008 09:39 #230300
by 650ed
Replied by 650ed on topic HELP! Need Piece of Exhaust Pipe
Hi Mark,
I sent a PM; thanks again!
