connecting rod cap direction
- keyzerdm
10 Feb 2006 13:18
I am rebuilding my 1978 KZ650C, and I found that 3 of the rod caps were put on so that the bearings were "tang-to-tang" and one had the tangs opposite. Which way is correct?
Thanks,
Thanks,
- APE Jay
- Duck
- e vica na i sau na ga
Re: connecting rod cap direction
10 Feb 2006 21:45
Unless you're replacing the bearings, I wouldn't worry about it.
They've worn in the way they are and changing them around may cause faster wear.
-Duck
Post edited by: Duck, at: 2006/02/11 00:50
-Duck
- wireman
- Duck
11 Feb 2006 05:27
Did I miss something?
We're talking about the tangs. These are the notches on the rod end and cap that the bearing tab fits into.
Or am I picturing this wrong?
The hole is cut with the cap on the rod.
Any error in center translates to offset when the cap is put on backwards.
This makes a high spot on each bearing at the seam.
If he's been runnng a while this high spot has worn down and the bearing is nice and round inside.
If he keeps the old bearings and turns the caps around he gets two new low spots.
Turning the caps around if the bearings don't need replacing buys nothing but trouble.
-Duck
-Duck
- wireman
11 Feb 2006 10:06
thats why i did the:whistle: thing ,no matter what he does here i see problems lurking unless he puts in a new set of bearings:S goodluck,happy wrenching!
- keyzerdm
12 Feb 2006 00:57
Thanks for the help. I am replacing the bearings so I will put them all tang to tang. I may have put the cap on backwards after I removed the rod, although I thought I was careful. I guess next time I will be sure to mark them all before removing them . . .
- wireman
12 Feb 2006 07:45
make sure the caps are numbered.goodluck,happy wrenching!
