650 camshaft setup
- Aesop
02 Aug 2008 13:08 #229711
by Aesop
650 camshaft setup was created by Aesop
I have 77 650D and replaced the bottom end with a 82 csr650 engine. I used the 77 head, but the cam chain is different, so I am using the 82 cams. Now I am stumped. The cam sprocket markings are very different, and there is no sprocket between the cams. I have searched this forum but came up empty. I am @ 1-4 TDC, but the cams have too much garbage printed on them.
What is the correct setup? Don't want to bend valves. Thanx.
- steell
02 Aug 2008 14:09 #229726
by steell
Replied by steell on topic 650 camshaft setup
First off, are you using the 82 cam cover also?
Secondly, what marks are on the cam sprockets?
I haven't seen the 82 cam sprockets, so I'm wondering of they use the same sprockets as the 750.
- anarki650
- Thank you received: 5
02 Aug 2008 16:19 #229750
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic 650 camshaft setup
I think you'll have to use the 82 head also. In 81 the kz650 switched to a hyvo cam chain that used different guides and tensioners internally. The pre-81 heads are going to have mounting points for the earlier model tensioners (including the top one you mentioned), which aren't there in the post-81 models.
09 Kawasaki ER6n
Omaha NE
- Aesop
02 Aug 2008 16:46 - 02 Aug 2008 16:55 #229764
by Aesop
Replied by Aesop on topic 650 camshaft setup
The exhaust cam has these numbers stamped in the sprocket
Z7EX (with a line underneath)
IN (below a hole)
Z6EX (with a line underneath)
Z7EX (below a hole)
IN (with a line underneath)
Z7EX
Does the IN with a line underneath line up with the edge of the valvecover surface? the old style chain sprockets had arrows.
IN (below a hole)
Z7EX (below a hole)
Z7EX
Last edit: 02 Aug 2008 16:55 by Aesop. Reason: Picture
- Aesop
02 Aug 2008 18:03 #229775
by Aesop
I am going to take it to the shop. Thanx guys.
- steell
02 Aug 2008 23:23 #229806
by steell
Just got home or I would have told you earlier that those are the same sprockets used on the 750 fours.
If you decide not to take it to a shop, you can download a 750 manual HERE and follow the instructions to set the cam timing.
