- Thank you received: 4
kz vs J compression decreaase
- themachine
01 Aug 2008 20:21 #229624
by themachine
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
kz vs J compression decreaase was created by themachine
i torched the pistons in my bike tonight, too much abuse, too hot, and maby not enough(or too much) e-85, it still runs, but i obviously need change.
anyways i want to sell my harley (i know:blush:) to build a motor from scratch, and i was curious what the drop of compression would be if one stuck a J head on a pre 80 kz1000 engine.
ape does not show any bigblock piston sizes for low compression turbo use, and i was hoping an 10.25kz would equal an 8ish J motor compression.
any help would be gratefull
and has anyone here had their crank welded and their tranny backcut and howmuch did it run you
- mtkawboy
- Thank you received: 16
01 Aug 2008 20:43 #229629
by mtkawboy
Replied by mtkawboy on topic kz vs J compression decreaase
-2 points in a post the other day
- steell
01 Aug 2008 20:58 #229634
by steell
Replied by steell on topic kz vs J compression decreaase
APE Jay ought to put me on the payroll
www.aperaceparts.com/tech/techkz1000.html
The J model / '81-'82 GPZ1100 cylinder head has a larger combustion chamber than the early style head. When these heads are used on the early style motor, a compression ratio drop of about 2 full points can be expected.
- supercharged
01 Aug 2008 23:44 #229643
by supercharged
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport......
Replied by supercharged on topic kz vs J compression decreaase
I know it is possible, but is it worth it... shave the Jmodel head to retain compression.
I asked a similar question yesterday as to why use the Jmodel head. Someone said it is cheaper... so therefore shaving the head to retain compression probably isn't a viable solution.
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
- themachine
02 Aug 2008 17:06 #229769
by themachine
Replied by themachine on topic kz vs J compression decreaase
the only reason i want to know this is that there are no low compression pistons listed for the J engine, and i want my next engine to be a low compression big block motor, expecting a turbo to be added to the bike in a year or two.
- supercharged
02 Aug 2008 20:15 #229789
by supercharged
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
Using a J model head with high compress (10s) will get you almost standard compression in the 8s. This provide a really lazy response with carbs, but perfect for forced induction.
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
