sealer for lower cases
- kzbasket
31 Jul 2008 17:31 #229439
by kzbasket
sealer for lower cases was created by kzbasket
sent cases,side covers,crank and trany out to be cleaned.
tomorrow i'am going to order a complete gasket set and all new bolts.what is the best sealer to use when i put it back together again ?
- FastKaw1
31 Jul 2008 18:36 #229459
by FastKaw1
Replied by FastKaw1 on topic sealer for lower cases
I put gasket on dry and yama bond on the case haves.
All gasket surfaces MUST BE clean and dry.
- RonKZ650
- Thank you received: 240
31 Jul 2008 20:45 #229484
by RonKZ650
Replied by RonKZ650 on topic sealer for lower cases
Yea, Yamabond #4 between the cases and dry on the rest. I learned a long time ago paper gaskets seal just fine without sealer if the surfaces are clean.
- coppertales
01 Aug 2008 08:03 #229536
by coppertales
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
Replied by coppertales on topic sealer for lower cases
I use Permatex #2 on the case halves. I use Permatex copper on the side cover gaskets, one side only. This holds the gasket in place when installing, same with the cam cover. I use this sealer on the threads of the end bolts of the cam cover too...chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
