milling head with no high compression piston
- odl666
31 Jul 2008 07:16 #229333
by odl666
1978 kz 650b with gpz faq mods cams carbs polished and ported
1979 gs750e
1972 bsa lightning under construction
milling head with no high compression piston was created by odl666
I have a 1978 kz 650 which i have milled the head 25 thous i also have a set of 1984 gpz cams and stock over sized pistons. will i run into any problems with clearence issues being that the pistons i am using are domed? thnaks
1979 gs750e
- BSKZ650
- Thank you received: 14
31 Jul 2008 07:30 #229336
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic milling head with no high compression piston
I dont think you will have any problems, but nothing like a clay check prior to final assembley to make sure, better safe than sorry
- steell
31 Jul 2008 07:44 #229343
by steell
Replied by steell on topic milling head with no high compression piston
You didn't say, but you did slot the cam sprockets so you could put the cams back in time after shaving the head, right?
On the clearances issue, same answer as above, except don't even think about assembling it without checking.
- odl666
31 Jul 2008 09:33 #229361
by odl666
1979 gs750e
Replied by odl666 on topic milling head with no high compression piston
Yes i hvae slotted the cam sprockets to adjuct the timing. I have done everything that the gpz faq says to do except for using a 810 kit. I have already assembled the motr but have never ran it. I have used stock kz 650 valves and springs as well as having the head ported and polished and milled 25 thous. the pistons i put in the motor are two over.
i thought by using the same valves it would eliminate a clearance issue from valve to piston. I also felt like the gpz cam springs and the kz 650 valve springs where no different. thanks for any help!
1979 gs750e
- Old Man Rock
- Thank you received: 225
31 Jul 2008 09:52 #229365
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic milling head with no high compression piston
Steell, "slot the cam sprockets"... Caught my eye, can you explain more on this please...
Reason I ask is I'm updating the KZ900 with .365 CAMs and was wondering if this is something I'm required to accomplish over the stock CAMs.
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- odl666
31 Jul 2008 10:27 #229370
by odl666
1979 gs750e
You can slot the cam sprockets even if you don't mill the head. Even with the new cams or with out them it would be a better upgrade to go head and slot the sprockets. cam chains get stretched throwing off the timing a bit. If you slot the sprockets and redegree the cams you will probably have a lil better performence. the only reason i slotted the sprockets is because i am milling the head to get better mid range from the cams thus making the cam chain longer making m have to change the degree of cams.
1979 gs750e
- steell
31 Jul 2008 10:59 #229378
by steell
Yep, what he said.
The reason for slotting the cam sprocket bolt holes is milling the head moves the cams closer to the block, effectively making the chain longer. The tensioner will take up the slack, but it's on one side while the slack is on both sides, so when it takes up the slack on the far side it rolls the cams toward the tensioner. So you slot the bolt holes to allow you to roll the cams back where they are supposed to be.
I read where someone else on here said the holes should be enlarged (elongated) by 1/3 the diameter of the hole. That makes absolutely no sense to me, elongating the hole by two thirds the amount removed from the head should be more than enough. Mill .030 off the head, make the hole .020 longer should work just fine. I'll know for sure when I assemble my motor, but my calculations say it will be more than sufficient.
- Old Man Rock
31 Jul 2008 11:56 #229390
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Interesting...
Anyone have any pictures of the sprockets completed?
Learning curve for us all...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- APE Jay
- Banned
- Thank you received: 58
31 Jul 2008 21:52 #229490
by APE Jay
Replied by APE Jay on topic milling head with no high compression piston
- donthekawguy
- Thank you received: 8
01 Aug 2008 04:32 #229511
by donthekawguy
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
Replied by donthekawguy on topic milling head with no high compression piston
APE Jay wrote:
What he said. It's a lot easier then spendy a day in the garage with a dremmel. :laugh:
Just pick up the phone and order a set.
kzzone.com/sprockets.html
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- APE Jay
- Banned
02 Aug 2008 13:16 #229713
by APE Jay
Actually I just read the first post again, and we don't make a sprocket for the 650.
Jay
Jay
- kzr750r1
- Thank you received: 9
02 Aug 2008 13:25 - 03 Aug 2008 12:21 #229717
by kzr750r1
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
Replied by kzr750r1 on topic milling head with no high compression piston
I have a set of GPz cams with the stock sprockets slotted. They are buried in the Garage but I'll pull them out and snap a shot.
Just for documenting what is possible.
Last edit: 03 Aug 2008 12:21 by kzr750r1. Reason: Adding pictures
