clutch taking it's time when I'm down on it
- BeeSting
- Drive it like your tax dollars already paid for it
30 Jul 2008 19:53 #229269
by BeeSting
BeeSting
Flint, Michigan - Chicagoland, IL
If I wasnt such a badass American, I would have to drive a Harley to make up for it
1980 Kawasaki KZ750 H1 LTD (4)
Kurayami (Girl of Darkness)æš—é—‡ã®å¥³
1980 Honda CX500C - GONE
Christine
clutch taking it's time when I'm down on it was created by BeeSting
So when I'm getting down on it, taking off kinda hard, sometimes when I shift quick into 3rd or 4th (from a high RPM) the trans doesn't seem to engage immediately. It kinda sounds like it's slowly engaging quite a while after I shift.
Any ideas? Am I wearing out my clutch?
BeeSting
Christine
- Thank you received: 2098
30 Jul 2008 20:00 #229270
by Patton
Replied by Patton on topic clutch taking it's time when I'm down on it
If not already done, this condition may often be corrected by performing routine clutch pushrod adjustment (not talking cable slack here ).
Good Luck!
Good Luck!
- steell
30 Jul 2008 20:13 #229274
by steell
Replied by steell on topic clutch taking it's time when I'm down on it
Either that or your clutch is worn out.
If adjusting it don't work, take a look at the clutch plates.
- coppertales
31 Jul 2008 07:36 #229338
by coppertales
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
Replied by coppertales on topic clutch taking it's time when I'm down on it
Sounds like clutch plate replacement to me. However, the pressure plate springs may just be weak. I had a set of weak springs in my number 2 bike that replacing them fixed the problem. Z1 had springs. Your clutch cable may be breaking inside the housing causing enough restriction making the clutch release slowly. chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
