KZ900 Oil Light - Input/experience Needed - Please
- Ilbikes
30 Jul 2008 19:51 #229268
by Ilbikes
KZ900 Oil Light - Input/experience Needed - Please was created by Ilbikes
Guys,
I put thousands of miles on my roommate's 1976 KZ900 32-33 years ago. I remember hard, full-throttle shifts between 1st and 2nd would get the oil light illuminated. I have just put my KZ900 back together after the new rings/Swain Tech pistons, and hone and started the break-in process. After 50 miles I've started making a few hard pulls to build full pressure in the cylinders so the rings aren't glazed before seating as the original owner did. I'm getting an oil light illuminating under hard accell in 1st - without the hard shift. Is this consistent and common for the stock KZ900? What about the modifieds - they would be slamming the oil to the rear of the cases even in higher gears?
I read years ago how RC Engineering would move the pick-up back and there are others who have modified the pan. My question is whether this is common among stock bikes and does anyone have a solution short of re-routing the pick-up?
Thanks in advance.
Gordon
Thanks in advance.
Gordon
- bill_wilcox100
- Thank you received: 5
30 Jul 2008 20:05 - 30 Jul 2008 20:43 #229271
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic KZ900 Oil Light - Input/experience Needed - Please
Some members have noted that under certain circumstances oil in the bottom of the engine will be pushed to the back of the oil pan and away from the oil pump input/screen. This apparently starves the oil pump and naturally the pump's output pressure falls. :ohmy:
I have seen posts describing a very simple modification that blocks the oil from being pushed to the back of the oil pan during hard acceleration.
This may be the cause of your low oil pressure under hard acceleration symptom. You will want to act accordingly or implement the modification. :dry:
Best of success.
Here it is... an "MTC-Oil Pan Gate" at less that $20...
Gatehttp://secure.mycart.net/catalogs/catalog.asp?prodid=327621&showprevnext=1
Best of success.
Upgrades:
Montreal, Canada
Last edit: 30 Jul 2008 20:43 by bill_wilcox100.
- MFolks
- Thank you received: 540
30 Jul 2008 20:34 #229279
by MFolks
Replied by MFolks on topic KZ900 Oil Light - Input/experience Needed - Please
Is this the original oil pump in your bike and did you change to oil as scheduled? (not every 6 months) the oil pump may be wearing out.
- Sandy
- Fly High,Tony
- Thank you received: 13
30 Jul 2008 20:41 #229280
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic KZ900 Oil Light - Input/experience Needed - Please
Ya,you can install what's called an "Oil-Pan Gate".
I looked around,but can't find any info for you.
Someone else will jump in soon...
1977 KZ1000 A-1
- Sandy
- Fly High,Tony
30 Jul 2008 20:59 #229283
by Sandy
1977 KZ1000 A-1
1977 KZ1000 A-1
- donthekawguy
- Thank you received: 8
30 Jul 2008 23:08 #229291
by donthekawguy
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
Replied by donthekawguy on topic KZ900 Oil Light - Input/experience Needed - Please
MFolks wrote:
I have never heard of an oil pump wearing out on one of these bikes. I would get the oil gate and see what happens.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
