- Thank you received: 43
Why is oil leaking from here??
- 79MKII
- Love Them Kaws!
31 Jul 2008 04:21 #229305
by 79MKII
The Kaw List:
Replied by 79MKII on topic What's the deal with crankcase breathers??
donthekawguy wrote:
There's a hose and filter on it now, but the hose is short. Maybe longer would help.
Sandy - Yes, the low-profile cover is new (among many other things). I would think that the low profile cover creates a lot more discharge - just waiting to get some confirmation. There are no internal baffles and a lot less space too.
You should try putting a hose on it and then put the filter on the end of the hose.
The Kaw List:
- 79MKII
- Love Them Kaws!
02 Aug 2008 20:02 #229787
by 79MKII
The Kaw List:
APE Jay, where are you?? Does the low-profile APE breather cover require the use of a catch tank? Could that be why I'm blowing oil out of the filter? Maybe a "race only" part??
Anyone??
Anyone??
The Kaw List:
- mark1122
- Keep twisting it
- Thank you received: 109
04 Aug 2008 15:26 #230163
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic What's the deal with crankcase breathers??
just put the stock cover back on for now.it has those rubber diverter tubes inside to direct the oil back down into the motor.the late kz's oil cup setup are dif and better then the z1's.your mk11 should be fine.
didnt u just add bigger pistons? that would give u more blow by untill the rings seat and more crank case pressure to creat this issue.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- 76 LTD
04 Aug 2008 15:41 #230167
by 76 LTD
Replied by 76 LTD on topic Why is oil leaking from here??
i have the low pro breather and it doesnt blow aany oil out.
- wiredgeorge
05 Aug 2008 06:20 #230268
by wiredgeorge
Replied by wiredgeorge on topic Why is oil leaking from here??
Couple of thoughts... One... The rings are new and need to be broken in. Oil will get by until the rings seat/seal. Take off that filter as it will just clog and stick a hose on the breather until the rings seat and you quit getting blow-by. Two... I had a low profile crank vent breather and installed it a couple years ago and it leaked like a sieve. I never figured out why as I used a new oring but it leaked around the edges badly.
If you have an oil leak and don't know where, CLEAN the engine and then spray it with some talcum powder based spray deodorant. New oil leaking will show easily in the residue left by the spray and you will be able to tell where the oil is coming from.
- 79MKII
- Love Them Kaws!
28 Aug 2008 05:33 #234389
by 79MKII
The Kaw List:
Replied by 79MKII on topic Why is oil leaking from here??
Forgot to update this thread -
I removed the APE cover and went back to stock - no oil leaking whatsoever! It's nice to have the extra room you get with the low profile cover, but I can't take all of that oil spewing everywhere.
To make sure everyone saw it in my earlier post - the oil leaking from the mystery hole was from the breather. It was running down the cavity under the middle of the long motor mount bolt and leaking out of the hole.
Problem solved for now...
The Kaw List:
- jimmybon
- Thank you received: 2
28 Aug 2008 05:47 #234391
by jimmybon
74 Z1A900 original
74 Z1A900 stone replica
74Z1A900 barn find
77 Z650B1 Hybrid
81 z650 PIG camp bike
06 ZRX1200R cafe racer project
S1000xr
Replied by jimmybon on topic Why is oil leaking from here??
The ape cover may be worped, perhapes check it on a perfectly flat surface.
also look at the o ring seal groove, whether theres any casting faults that may impead sealing
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
- 79MKII
- Love Them Kaws!
28 Aug 2008 05:52 #234392
by 79MKII
The Kaw List:
jimmybon wrote:
Thanks but the breather seal isn't leaking, it was just oil blowing out of the filter on the breather and leaking onto the engine.
The Kaw List:
