Idle issues
- Justyn
When the engine is cold, it idles good, about 1000-1500 RPMs. Once it gets hot, it idles between four and five grand. While driving, everything seems fine, unless I make a real slow shift, like hold in the clutch for a second or more, then it idles up. I don't know much, but I'm a little puzzled why it runs better cold than hot. My first guess is that the throttle is sticking, but I don't really understand why it would only stick when it's hot. While driving, releasing the throttle causes it to coast slowing down, which seems to shoot a fairly large hole in my theory. Any insight would be much appreciated.
By the way, it's an 80 kz750h (LTD-4).
1980 750 LTD (kz750h) Wausau, WI
- saxjonz
- KawboyZ
- Thank you received: 76
79 LTD B3
- Hagphish
\'81 KZ550
\'99 XLS
Whatever puts wind in your face
- Justyn
I also like the idea of starting simple.
When I rev it up cold, it drops back down just like I think it should. I've never really revved it hot as it is already at five grand or so. This morning when I pulled into the parking lot at work, it was up around five grand while clutched, but when I put it in first gear, the RPMs dropped to around 2000-2500 while I was putting along to park. I'm not sure if that gives any clues or not.
I hope it's not a vacuum leak, as those can be a real PIA to track down.
- Z1109R Fin
- Thank you received: 1
Z1000R ´83...Slightly modified...
- Justyn
Air leak on carb boots/holders (those rubber "hoses" connecting carbs to engine intake). Those are not too expensive just first change them. www.z1enterprises.com/catalog.aspx?pid=KPCF0
I've visually inspected them (while on the engine) and they looked ok. But that doesn't mean that they don't leak and I can't see it.
I've put about 240 miles on the bike since Saturday, and the problem seems to slowly be getting better. I guess it could just be from sitting for a year or so, and might just correct itself. I think right now, I might just put some more miles on, and see if it changes at all.
- anarki650
- Thank you received: 5
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
- Z1109R Fin
- Justyn
- MFolks
- Thank you received: 540
- Justyn
MFolks wrote:
Go to the local auto parts store or wally world and buy a can of "seafoam"
I poured some seafoam into the last two tanks of gas, and it has made no difference, other than maybe the engine needing to be a little hotter to rev high than before, and that's a stretch.
I gave the fuel lines a quick inspection on Sunday, and everything appeared to be in order, but I really need to get a manual so I can be more sure about things.
The only guess I can come up with right now for the culprit is something sticking when it gets hot. I just would've thought that would be a little less regular, and that it would've gotten better or worse in this amount of time.
I have no idea what I am doing as far as checking the carbs, so I think I'm going to have to wait until I get a manual to do that. If anyone can offer any other theories to check, I would appreciate it. The easier the test, the better, cause I'm a real noob.
