Plug Fouling Causes
- BeeSting
- Drive it like your tax dollars already paid for it
Plug Fouling Causes
25 Jul 2008 20:57
I need to pull some plugs again and check out whats going on.
My question is - is plug fouling common and why does it happen?
Also, if my exhaust manifolds (where they connect to the engine) were extremely loose and loud, could that contribute to plug fouling?
BeeSting
Flint, Michigan - Chicagoland, IL
If I wasnt such a badass American, I would have to drive a Harley to make up for it
1980 Kawasaki KZ750 H1 LTD (4)
Kurayami (Girl of Darkness)æš—é—‡ã®å¥³
1980 Honda CX500C - GONE
Christine
Christine
- MFolks
Re: Plug Fouling Causes
25 Jul 2008 21:44
A clogged air filter,incorrect carb settings and/or weak ignition system all can add up to sparkplug fouling.
Have you done a compression test and have the valves been adjusted lately?
Hopefully it's not a broken oil control ring on the piston(s)as this can also lead to fouling.
Have you switched the brand of sparkplug from what worked in the past? I've heard good things about the denso brand of plug(used to be called nippon denso).
- BeeSting
25 Jul 2008 21:50
Well the carbs were just redone so I'm hoping there's no issue there. The plugs havent been replaced since, though.
The previous owner is responsible for the current plugs. I think he had said something about fouling but I don't remember.
Its going to be a little while before I can do anything, even rent a device to check compression. After my trip to Ft Knox last week my bank account is negative.
BeeSting
Christine
Christine
- bountyhunter
25 Jul 2008 23:09
The worst fouling is when the valve guides start to leak and oil drains down onto the plugs.
