Clutch cable question.
- NickW900LTD
- Nick
22 Jul 2008 14:54
I changed over to superbike bars on both of my 1000's. The LTD has a shorter clutch cable and noticed how much smoother it runs around town. The A2A model is still using the stock clutch cable witch is way longer and notice some clutch chatter at low revs around town, but its fine on the highway. Will a shorter cable take the chatter away or is it common to have a little chatter when riding around town?
1976 KZ900 LTD (sold)
1977 KZ1000 LTD
1978 KZ1000 A2A
Pierceton, Indiana USA
1977 KZ1000 LTD
1978 KZ1000 A2A
- supercharged
Re: Clutch cable question.
22 Jul 2008 15:01
I don't like the sound of chatter....
How does the cable feel? Is there still enough play? Dis you test this while moving the bars from end to end? If there is ample play, then other than possible cable binding due to extra length, I think the cable will be fine.
The chatter on the other hand....
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport......
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
- coppertales
23 Jul 2008 08:53
The only reason, that I can think of, where a cable would cause the clutch to chatter is if it was binding and not allowing the clutch to fully engage. Did you check the cable to see if it was moving freely when you made the swap?...chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
